Pic of GSR brake MC/booster in an EG civic request
I am more than likely getting a GSR MC/booster for my brake upgrade, but I want to see how bad the rebending of the lines is.
free bump, well because I have been wondering my self.....
My suggestion is possibly going to honda and gettin a hard brake line extender that has a "U" shape to it so it could then lead to the other side of the GSR brake booster......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote"> https://honda-tech.com/zerothread?id=607731&page=1 </TD></TR></TABLE>
That's a RS MC, I am looking for a GSR MC, because they are different, the lines don't line up like the RS's do. I found someone with one, that's why I am asking.
use a 98 and up GSR and the lines don't have to be reflared, just bent a little. Use a tubing bender, or you will kink the line. sorry, no pics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR »</TD></TR><TR><TD CLASS="quote">use a 98 and up GSR and the lines don't have to be reflared, just bent a little. Use a tubing bender, or you will kink the line. sorry, no pics.</TD></TR></TABLE>
I know they need to be rebent, I want to see how much, if it's going to be a real pain in the ***, I'll just try to find a RS MC.
There are two 'versions' of the gsr master cylinder. I got the 'wrong' one in which lines need to be re-bent and one line reflared. The line bending was no problem...mine is a little ugly, but I dont give a damn.
The line flaring was slightly more tricky, but still a fairly easy proposition. I purchased the flaring tool from my Local autozone for 20ish dollars, and went to town. This procedure took all of 5 minutes, and worked flawlessly even with the POS tool I bought.
My only other advice to you is to make sure you recive the flare nuts from the new/used MC that you are picking up. Just in case you end up getting the one that requires a little more masaging like mine did.
hope that helps....sorry i have no pictures , I cant seem to keep up with new technology and have no digicam
Don't even buy the flaring tool. Buy the lines pre-flared from Advance, etc.
Get the double flared, also known has inverted flare, lines with metric fittings. I bought the flaring tool and it was a POS, wouldn't hold the line in place.
In any case, with the pre-flared lines and a beer bottle to do the bending, you can use the GSR master without a problem.
Ben
Ben
if you're rich or know a good junkyard that has a GSR there, just get the 2 lines that come off the firewall that go to the M/C. I think that'll make it a direct bolt on, but the lines are like $80 each retail.
what i did go buy a shortest metric double flare brake line, and a metric union or coupling, then cut 1 end bent it into a u shape and reflare the part that you cut, and remmber to put the fitting that would fit into the gsr mc. after you done making the u brake line use the union or coupling the join the exiting brake then you are done. nice and neat. imo
underb00steg6
10
Mar 31, 2007 10:38 AM
ventturei27
Nov 22, 2006 07:58 PM
badpootie
12
Apr 17, 2005 08:44 AM
