Questions about: p30 and knock sensor...
Old Dec 1, 2003 | 11:32 AM
Se-rv-Tak's Avatar
Default Questions about: p30 and knock sensor...
I am going to be running a CRVtec, with a p30 ecu. On my b20 block, I have no knock sensor, there is a port for one. Will I need the knock sensor? or does the p30 not have a knock sensor?
Old Dec 1, 2003 | 11:50 AM
AzG35's Avatar
Default Re: Questions about: p30 and knock sensor... (Soon2B18Boost)
If the ECU is not chipped, it will look for a knock sensor. You need to either add one in or get the ECU chipped so it won't look for it. A p30 ecu won't provide enough fuel for the B20 anyway, so I would get it remapped or upgrade to hondata.
Old Dec 1, 2003 | 12:00 PM
Se-rv-Tak's Avatar
Default Re: Questions about: p30 and knock sensor... (AzSi22)
ya I know that my fuel will be running lean, but this is for now. If worse comes to worse, I might have a p13 I can use... lol
Old Dec 1, 2003 | 12:35 PM
PHiZ's Avatar
Talk to PHiZ, he'll chip your ecu for a good price, and he's a sexy man-beast to boot
-PHiZ
Old Dec 1, 2003 | 01:52 PM
Se-rv-Tak's Avatar
Default Re: Questions about: p30 and knock sensor... (PHiZ)
lol can you really chip it? if so how much?
Old Dec 2, 2003 | 01:17 PM
Se-rv-Tak's Avatar
can I swap my D16y7 KS and put it in my b20b4 block>?
Old Dec 2, 2003 | 02:59 PM
PHiZ's Avatar
d16y7 doesn't have a knock sensor, only DOHC vtec engines do.
-PHiZ
Old Dec 2, 2003 | 05:16 PM
Se-rv-Tak's Avatar
my d16y7 has a knock sensor, I have already checked..... most 96-98 has KS.
Old Dec 2, 2003 | 07:26 PM
Se-rv-Tak's Avatar
Default Re: Questions about: p30 and knock sensor... (cbpro)
what is VTEC X-over on the p30? isn't it 5500? I know the fuel maps are too low for a CRVtec, but that will be changed later.
Old Dec 2, 2003 | 07:42 PM
chrisCNL's Avatar
1-a p30 has KS on it so use it...2-96-00 civic EX has KS on them and yes you can use the ks from it or if your harness is different you can use the 94-95 KS.
Old Dec 2, 2003 | 09:04 PM
Se-rv-Tak's Avatar
Default Re: Questions about: p30 and knock sensor... (chrisCNL)
mmm ok, I could have sworn my DX has a KS on the back of it, I checked myself... but I could have felt something else I suppose..
1.5boosted
Dec 14, 2007 01:45 PM
96 GSR-T
Jun 30, 2006 09:31 PM
530guy
May 7, 2006 05:44 AM
untitled
Aug 8, 2003 08:03 PM
