ECU
Old Dec 1, 2003 | 08:55 AM
rockeyH22's Avatar
Default ECU
what ecu should i have w/ h22? or which would be better to have?
Old Dec 1, 2003 | 11:22 AM
Spartanic's Avatar
Default Re: ECU (rockeyH22)
The best one would be the ECU that was made for the Preludes that came with the H22.
Old Dec 1, 2003 | 11:37 AM
infinkc's Avatar
Default Re: ECU (Spartanic)
p13 vtec
Old Dec 1, 2003 | 12:12 PM
HAccord96's Avatar
I have a p13 vtec ecu if you need it.
Old Dec 1, 2003 | 01:19 PM
rockeyH22's Avatar
no ****.........its screwed up, and i was told a different one would be better because the redline would be higher and vtec would kick in sooner...........whats w/ all the smart asses on here, seriously, can you not ask a question w/out getting some smart *** remark back?
Old Dec 1, 2003 | 01:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockeyH22 &raquo;</TD></TR><TR><TD CLASS="quote">...........whats w/ all the smart asses on here, seriously, can you not ask a question w/out getting some smart *** remark back?
I'm looking but don't see anything but good valid replies. Not getting the answer you want?
Old Dec 1, 2003 | 06:13 PM
Nick H's Avatar
New User
Default Re: ECU (Chiovnidca)
it depends on the setup you are or are planning on running...in all reality, a p72 is more tunable (gsr ecu)...if you have no secondary intake runners (i.e. using the type r intake manifold) a p28 will suit you fine...it's all about what you have...the stock ecu is the p13 in which case you should use if your motor is in stock form...
Old Dec 2, 2003 | 09:48 AM
rockeyH22's Avatar
Default Re: ECU (Nick H)
yeah, i have the p13, which of course is what the motor came with.......but for some reason with that ecu my redline is like 6800rpms......and my vtec has never worked...........and i still haven't got it running again since it randomly died when i was driving......the guy that has it said it needed a distributor, so he replaced that, now he says the computer doesn't respond....so i really have no idea what the hell is wrong w/ it. its been there for like 3 weeks............i think i explained that whole situation to you before, about when it stopped running......am i correct?
also what do you mean by the motor being in stock form?
Old Dec 2, 2003 | 09:56 AM
Nick H's Avatar
New User
stock intake manifold, stock internals, stock injectors and all that...
just so you know, i'm having the same troubles as well with my h22 right now...i'm throwing codes 10 and 14 though, which both ended up being problems with the ecu...i'm replacing it though with hopes that it cures all the problems...it appears that this might be the same for you...are you throwing any codes?
Old Dec 3, 2003 | 07:52 AM
rockeyH22's Avatar
yes...........egr, o2, vtec, and one more...i think 41...........
but i have the egr blocked and the a6,a11pins switched.....so that explains the egr and o2..................so yours won't start at all?
Old Dec 3, 2003 | 08:46 AM
Nick H's Avatar
New User
no mine runs, i just am limping with no vtec and running rich....code 10 is the IAT...code 14 is the IACV...anyways, make sure that all your connections are good, and get out a voltmeter to test continuity from the pins from your ecu to the sensors...also test for power to each of your connections...
Old Dec 3, 2003 | 01:35 PM
rockeyH22's Avatar
i'm almost positive the ecu is bad.......u know where i can get preferably a p72, but anything that will work and is cheap will be fine...i just need to get it running.
i called acura.....they told me $907.......i was like yea right
93JDM_H22
Feb 7, 2008 07:33 PM
trustkill
Dec 4, 2007 04:49 AM
01accordh22
Mar 27, 2005 08:49 PM
hondaturtle
Mar 21, 2005 10:59 AM
98civic4dr
Oct 20, 2004 01:09 PM
