To all turbo Preludes
Old Dec 1, 2003 | 06:20 AM
dominate9's Avatar
Default To all turbo Preludes
Do any of you guys have your timing retarded for boost? If so, how much? I tried retarding mines by .75 degrees and again at .5 degress. My car seems slower. It was faster when the timing wasn't retarded.
Old Dec 1, 2003 | 07:33 AM
TurboSam's Avatar
Default Re: To all turbo Preludes (dominate9)
it will get slower with retarded timing, it affects turbo spool and performance. my car ran like *** on backed off timing, however, it was safer, but if you wanna push the limits and make good power, do not pull timing unless absolutely necessary
Old Dec 1, 2003 | 08:29 AM
IloveNewt's Avatar
You need to get hondata bro.
Old Dec 1, 2003 | 12:04 PM
Old_Nocturnal's Avatar
If you have a way to tune your fuel system, I would goto a dyno and get the air/fuel at a good, safe level. That combined with a good set of colder plugs (I recommend ZEX) should keep you out of trouble for a while without messing with the timing.
Old Dec 1, 2003 | 12:07 PM
graphic's Avatar
Default Re: To all turbo Preludes (Nocturnal)
.5 degrees @ 6psi
Old Dec 4, 2003 | 05:05 AM
dominate9's Avatar
I think I can run 10psi without any timing being retarded at all. On 15 psi with a 0.1 degree per psi, I get detonation occasionally. Using the Crome program, I'll probably leave 1-10psi unretarded and the retard 10-25 at .5 degrees per psi intervals. That seems like it would be safe. I wish there was a magic number or a formula to figure out how much timing needs to be retard.
turbo boost
Oct 19, 2007 01:57 PM
Benjithx
Jan 13, 2005 11:01 AM
bmm89
Nov 21, 2004 08:17 PM
wzcb08
May 19, 2003 07:47 PM
wrXtian
Mar 25, 2003 03:55 PM
