Un hooking vafc "Q"
Old Dec 1, 2003 | 06:16 AM
tegon-gsr's Avatar
Default Un hooking vafc "Q"
If you have a vafc hook up and i want to disconect it to go threw inspection, will every thing just reset back to stock as far as my car ecu. and after just plug it back up and everything should be back to as i program it ? cause all i was going to do was un plug the the unit not take of all the wire that were ack on the ecu.
Old Dec 1, 2003 | 06:42 AM
Home Skillet's Avatar
Default Re: Un hooking vafc "Q" (tegon-gsr)
If you unplug it, it won't start.
Old Dec 1, 2003 | 07:10 AM
IN VTEC's Avatar
You have to reconnect the MAP and VTEC wires. Those two are wired in series with the AFC, while the rest are wired in parallel.
Old Dec 1, 2003 | 11:54 AM
AzG35's Avatar
I think there are multiple questions there. If you unplug it, and try to start it, the ECU will throw a MAP, VTEC and TPS code, it will probably run, but like crap. If you unplug it, it will keep all your settings, it is stored inside the unit through a battery.
Old Dec 1, 2003 | 01:35 PM
tegon-gsr's Avatar
Default Re: Un hooking vafc "Q" (AzSi22)
ok thanks
ham
Jul 31, 2005 05:51 PM
Mr. Vapor
Apr 26, 2005 10:39 AM
STG3PWR
Oct 13, 2004 09:14 AM
Snail Tuning
Nov 4, 2003 06:18 PM
2000blacksi
Aug 27, 2002 10:28 AM
