need help
Old Dec 1, 2003 | 05:54 AM
skip.two's Avatar
Default need help
okay, so i'm driving normally only going about 30mph, and my car just dies on me. i don't think its the battery because the electronical stuff works on the car and i tried to jump start it many times. all the belts seem to still be okay from looking at it, none snapped. think it could be the spark plugs?? what else can it be??
Old Dec 1, 2003 | 06:00 AM
Grimm's Avatar
Default Re: need help (jL iLLuZiOnz 9)
any type of smoke? could be lots of things...
Old Dec 1, 2003 | 06:03 AM
skip.two's Avatar
Default Re: need help (Grimm)
nope, no smoke.
Old Dec 1, 2003 | 06:19 AM
skip.two's Avatar
anybody else???
Old Dec 1, 2003 | 08:04 AM
skip.two's Avatar
some people are telling me that its the distributor.. anybody else...?
Old Dec 1, 2003 | 10:31 AM
skip.two's Avatar
Old Dec 1, 2003 | 11:16 AM
The Internet Tough Guy's Avatar
this is a shot in the dark, but my roomates car did the same thing due to a bad ecu. but it wasn't a honda.
Old Dec 1, 2003 | 11:26 AM
2faz2paz's Avatar
what year car is it? there is a recall on the ignitions on 96-98 civics i beleive for it doing the same thing you described
Old Dec 1, 2003 | 11:30 AM
scratchy's Avatar
pull the plugs and check the dist. but make sure the ignition coil is working but it could be anything, is the whole car dying like electronics and everything more details
Old Dec 1, 2003 | 11:33 AM
EL Vap133's Avatar
Maybe your alternator, or a snapped alternator belt? When my timing belt went out, it was still in tact but the teeth had ripped off so it could still be your timing belt. Did you check to see if the rotor was and had not fallen off? That tends to happen too...
Old Dec 1, 2003 | 11:34 AM
Spartanic's Avatar
Get a Helms or auto service manual for your car, test out the ignitor coil with a mulitmeter and compare what you get to the specs in the manual. Test the resistance of the spark plug wires and compare it to the manual specs. You can get the full details on testing these parts in a serivce manual for your car.
Old Dec 2, 2003 | 05:11 PM
salbaje's Avatar
you looked at the timing belt?? dist??
AnHeL need help
Feb 17, 2017 03:51 PM
Ener Won
Oct 19, 2016 11:13 AM
97H22
May 1, 2003 09:10 AM
Timmayeg
17
Apr 29, 2002 07:34 PM
