Heat shield under the car is rattling, can I remove it safely?
Old Nov 30, 2003 | 09:38 AM
SuicideSlide's Avatar
Default Heat shield under the car is rattling, can I remove it safely?
Hey guys, I just recently swapped my 94 dx out for a b series. I also have 4-1's on it. After about a week I now hear rattling coming from under the car around 3.5-5k rpms. Can I safely remove the heat shield? Could it be something else causing this vibration noise?
Old Nov 30, 2003 | 09:39 AM
Ricey McRicerton's Avatar
Default Re: Heat shield under the car is rattling, can I remove it safely? (Tur*bLu)
Yes there are other things that can cause it, but yes you can remove the heat shields.
Old Nov 30, 2003 | 09:41 AM
blackhatchy's Avatar
Default Re: Heat shield under the car is rattling, can I remove it safely? (Ricey McRicerton)
cant you tighten it also?
Old Nov 30, 2003 | 09:59 AM
93hatched_projekt's Avatar
Default Re: Heat shield under the car is rattling, can I remove it safely? (blackhatchy)
I had this happen to me once, The welds on the heat shield broke loose , and it was chattering bad. I just removed the shield and have had no probs since........be careful , cuz the cat gets hot..........
Old Nov 30, 2003 | 10:03 AM
Default Re: Heat shield under the car is rattling, can I remove it safely? (93hatched_projekt)
my bad, didnt know it was welded on
Old Nov 30, 2003 | 10:04 AM
func-tion's Avatar
On my old car I had removed every shield for the exhaust and never encountered any problems.
I also experienced a rattle that your describing that came from the itake manifold brace but if you havent messed with that at all I wouldint bother.
Old Nov 30, 2003 | 10:07 AM
Navid OG's Avatar
Mine was rattling a long time ago and i took my car to my shop (friends so they dont charge) to see what the hell was going on and it was my heat shield but it wasnt welded on.... i just removed it with hand and it was done and done....
Modified by Navid OG at 4:05 PM 11/30/2003
Old Nov 30, 2003 | 12:03 PM
Default Re: Heat shield under the car is rattling, can I remove it safely? (Navid OG)
So I wont need any tools to remove those sheilds... cool...
ricer mentality note- weight savings of .000008 ounces = .0000001 faster times in the 1/4....
Old Nov 30, 2003 | 12:07 PM
Navid OG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tur*bLu &raquo;</TD></TR><TR><TD CLASS="quote">So I wont need any tools to remove those sheilds... cool...
ricer mentality note- weight savings of .000008 ounces = .0000001 faster times in the 1/4....</TD></TR></TABLE>
lol w0rd....... just jack up ur car and see whats going on... maybe the weld came lose and u can take it out with ur hand (like my case) or maybe its not even ur heat shield.... but like said before by somene else be carefull cuz it can get hella hot.
Old Nov 30, 2003 | 12:34 PM
BauleyCivic's Avatar
Risky Business
Mine was bolted on. The areas around the bolts on the lower heat shield of my cat had completely rusted off...it was being held on by 1 bolt...I ripped that thing off and havent had a problem since
Old Nov 30, 2003 | 01:43 PM
Evil_gambit's Avatar
Default Re: Heat shield under the car is rattling, can I remove it safely? (BauleyCivic)
i removed mine on my 98 hatch, and the only thing that happens is that my center console now gets a little hot
Old Nov 30, 2003 | 01:47 PM
Default Re: Heat shield under the car is rattling, can I remove it safely? (Evil_gambit)
So the shifter also probably gets hot as well huh?
Old Nov 30, 2003 | 01:50 PM
yea it gets hotter then normal
Old Nov 30, 2003 | 01:51 PM
func-tion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tur*bLu &raquo;</TD></TR><TR><TD CLASS="quote">So the shifter also probably gets hot as well huh?</TD></TR></TABLE>
Yah mine did but I had a plastic spoon shift nobb and it didnt transfer the heat so I didnt notice it unless I touched the metal part wich was just warm at the most..
vegaspartyy
Aug 14, 2006 05:15 PM
Rick
Apr 12, 2004 05:04 PM
Spade
23
Jul 30, 2002 04:27 PM
ekimmel
Apr 16, 2002 10:14 AM
slimbo
Mar 24, 2002 11:36 AM
