Ek wiring information SWAPS
Old Nov 29, 2003 | 03:14 PM
length's Avatar
Default Ek wiring information SWAPS
I am having trouble swapping my b18b1 into my 2000 hatch.
1. Idle at 2000 rpm. (could it be idle control vaulve?)
2. Rpm Gauge does not work after trying new harness.
3. I got the wobbles when i push the gas feels like the damn thing is gonna fall out( and yess all mounts are tight).
If anyone has any wiring information that could help my idle problem and the rpm gauge problem that would be great thanks, and yes i have searched and cannot find anything thanks guys.
Old Nov 29, 2003 | 04:00 PM
VTECVillain's Avatar
Default Re: Ek wiring information SWAPS (Jdm Ek Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm Ek Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I am having trouble swapping my b18b1 into my 2000 hatch.
1. Idle at 2000 rpm. (could it be idle control vaulve?)</TD></TR></TABLE>
The IACV could be the problem but this could also be due to a vacuum leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">2. Rpm Gauge does not work after trying new harness.</TD></TR></TABLE>
Is it only the tachometer that's not working? If so, did you do any wiring at the distributor/ECU that would have possibly affected it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">3. I got the wobbles when i push the gas feels like the damn thing is gonna fall out( and yess all mounts are tight).</TD></TR></TABLE>
Are ALL mounts used? The reason I ask is because some people leave off the front lower tranny mount and A/C mount bracket which can cause the motor to rock back and forth. Could be a bad axle(s) or suspension problem. Lots of possibilities...
Old Nov 29, 2003 | 09:21 PM
length's Avatar
Default Re: Ek wiring information SWAPS (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
Are ALL mounts used? The reason I ask is because some people leave off the front lower tranny mount and A/C mount bracket which can cause the motor to rock back and forth. Could be a bad axle(s) or suspension problem. Lots of possibilities...</TD></TR></TABLE>
1. the tach worked with the stock wiring, i was told to try an ex wiring harness. after installing that it got all messed up. the tach worked with the ls wiring, but the speed didn't. now the speed works but the tach does not.
2. the idel works fine when you unplug the iacv.
3. all mounts are in. I have stock suspension, but the axels could bad anyway to check them?
marinse
Dec 9, 2007 12:28 PM
mike-Ej8
Jun 3, 2007 06:05 PM
crx00
Mar 13, 2004 06:39 AM
slammin86
13
Jan 9, 2004 05:36 PM
