First modification for a TYPE-R
I want to know what would be first thing you would modify for your ITR? I'm planning to use a re-programmable ECU then Exhaust system. Any ideas?
My first mod was a CAI but in retrospect I'd say;
JDM Header with HF cat! I went with the Spoon 4-2-1 and Carsound cat and felt good results but, there are a number of good Header choices: JDM OEM, Hytech, Spoon, Mugen, and I also hear good stuff about SMS products. Also to consider is weather you want to do a HF cat, JDM/OEM Or a testpipe.
There are +'s and -'s to every setup , you need to just gather as much information that you can and make an educated decision.
Good luck,
A.
PS my dyno will be posted soon "in 2 weeks."
Good luck,
A.
I agree with George. Unless you are an experienced racer/autocrosser, I'd recommend a season of autocrossing/track events.
Use the money on a driver's school.
first mod : Injen Cold air , H&R sports , a set of Falken Azenis , and hit the road course.
. learn how to drive it and you will have soo much fun with just that.
I highly recommend one with the Pheonix Yellow R, but if you have a FBP or NBP R then a radar detector is overkill. No one notices you with a black car..
Oh yeah, for your first mod, I'd do the intake or just go to autox for a year
[Modified by arren123, 1:08 PM 9/16/2001]
I say the best mod you can ever do is to put in a lightweight flywheel!!!!!! IMO the first mod you should do. Also the only mod you'll really feel a difference with.
How much does that cost to do?
For me it would be the brake pads. If you do aggressive street driving the stock pads are not sufficient.
While you're @ it, you should replace your brake fluid with a higher quality one.Then get yourself some driver training and head to the race track!! That will really demonstrate what the ITR can do and highlight why the 'R' stands for Racing.
I have EBC 'Green Stuff' fitted to my ITR (with Castrol SRF brake fluid) and they are fantastic, from cold and have never faded on me....even after doing 15 straight laps on a race circuit (braking from 175km/h @ the end of the main straight!).
Checkout the following related links -
http://www.ebc-brakes.com/autopads.htm
http://www.castrol.com.au/castrol_00...ducts_set.html
I'm looking @ installing the Mugen: N1-ECU (with the uprated Valve Springs), Twin-loop Exhaust and maybe the 4-2-1 Exhaust Manifold as well (plus some other smaller components)....anyone have any comments on them (see the below link)?
http://www.kingmotorsports.com/produ...gra/engine.asp
i agree with the suggestion about upgrading the driver..is a very humbling expirience when your mugenR is pounced by nearly stock R's..hahahaha..
