First modification for a TYPE-R
Old Sep 16, 2001 | 05:09 AM
SLJ's Avatar
SLJ
New User
Default First modification for a TYPE-R
I want to know what would be first thing you would modify for your ITR? I'm planning to use a re-programmable ECU then Exhaust system. Any ideas?
Old Sep 16, 2001 | 05:15 AM
MiraiZ's Avatar
Default Re: First modification for a TYPE-R (SLJ)
ECU should be one of the last things changed....do intake and exhaust first
Old Sep 16, 2001 | 05:25 AM
JDM_DOHC_SiR's Avatar
New User
Default Re: First modification for a TYPE-R (MiraiZ)
#1) Intake
#2) Exhaust
#3) Header.."If you don't plan of FI later down the line.
Old Sep 16, 2001 | 05:58 AM
Edwin's Avatar
For me it would be the brake pads.
If you do aggressive street driving the stock pads are not sufficient.
Old Sep 16, 2001 | 06:24 AM
H-PIMP's Avatar
Default Re: First modification for a TYPE-R (Edwin)
Drop-in air filter and remove silencer.
Old Sep 16, 2001 | 06:28 AM
Dipshit Dan's Avatar
Yep here you go:
Header/test pipe
Intake
exhaust
crank pulley
cam gears
and on down the list. No need for new ECU with just mild bolt ons.
Old Sep 16, 2001 | 06:38 AM
1GreyTeg's Avatar
My first mod was a CAI but in retrospect I'd say;
JDM Header with HF cat! I went with the Spoon 4-2-1 and Carsound cat and felt good results but, there are a number of good Header choices: JDM OEM, Hytech, Spoon, Mugen, and I also hear good stuff about SMS products. Also to consider is weather you want to do a HF cat, JDM/OEM Or a testpipe.
There are +'s and -'s to every setup , you need to just gather as much information that you can and make an educated decision.
Good luck,
A.
PS my dyno will be posted soon "in 2 weeks."
Old Sep 16, 2001 | 07:14 AM
Honda318dx's Avatar
Default Re: First modification for a TYPE-R (1GreyTeg)
First mod, Track Event! Then you will realize you don't need to do anything to the car!
Old Sep 16, 2001 | 08:28 AM
timberwulf's Avatar
Default Re: First modification for a TYPE-R (George Knighton)
I agree with George. Unless you are an experienced racer/autocrosser, I'd recommend a season of autocrossing/track events.
Use the money on a driver's school.
Old Sep 16, 2001 | 08:32 AM
i 4's Avatar
i 4
first mod : Injen Cold air , H&R sports , a set of Falken Azenis , and hit the road course. . learn how to drive it and you will have soo much fun with just that.
Old Sep 16, 2001 | 08:33 AM
jond's Avatar
Default Re: First modification for a TYPE-R (timberwulf)
radardetector
Old Sep 16, 2001 | 08:44 AM
tjtruong's Avatar
New User
Default Re: First modification for a TYPE-R (jond)
radardetector
HAHAHHAHAHH
Old Sep 16, 2001 | 09:40 AM
Tommy_Gunns's Avatar
radardetector
I second that...I have yet to get a speeding ticket since the purchase of my radar detector (knock on wood).
Old Sep 16, 2001 | 12:07 PM
arren123's Avatar
I highly recommend one with the Pheonix Yellow R, but if you have a FBP or NBP R then a radar detector is overkill. No one notices you with a black car..
Oh yeah, for your first mod, I'd do the intake or just go to autox for a year
[Modified by arren123, 1:08 PM 9/16/2001]
Old Sep 16, 2001 | 12:09 PM
Ghetto Racing's Avatar
New User
Brakes
Suspension
Than the engine work.
But it all depends on what you'll use it for.
Old Sep 16, 2001 | 12:12 PM
ITR-585's Avatar
Default Re: First modification for a TYPE-R (F1 Soul)
I say the best mod you can ever do is to put in a lightweight flywheel!!!!!! IMO the first mod you should do. Also the only mod you'll really feel a difference with.
Old Sep 16, 2001 | 12:14 PM
SpoonCivic's Avatar
New User
Intake,
then Header w/ test pipe
cam gears
then Fields VAFC and an A/F ratio Gauge
Old Sep 16, 2001 | 12:19 PM
ITR1078's Avatar
New User
Upraged alarm, so you still have a car to modify.
Old Sep 16, 2001 | 12:21 PM
ITR1078's Avatar
New User
Default Re: First modification for a TYPE-R (ITR1078)
yes, upraged hehehe...
Old Sep 16, 2001 | 12:27 PM
Mike M's Avatar
Founding Member
Comptech Drop In Filter or Icebox, and then a JDM ITR 4-1 or Spoon Header with High flow cat.
Old Sep 16, 2001 | 12:28 PM
jond's Avatar
Default Re: First modification for a TYPE-R (ITR-585)
How much does that cost to do?
Old Sep 16, 2001 | 01:05 PM
Mike M's Avatar
Founding Member
ABout $450 for the Toda flywheel and Install is 250-300, I would say do the clutch and flywheel at the same time to save money on install costs
Old Sep 16, 2001 | 01:43 PM
Aussie_ITR-0239's Avatar
New User
For me it would be the brake pads. If you do aggressive street driving the stock pads are not sufficient.
I totally agree with that....if you're gonna be going faster, you want to be able to stop just as quick!! While you're @ it, you should replace your brake fluid with a higher quality one.
Then get yourself some driver training and head to the race track!! That will really demonstrate what the ITR can do and highlight why the 'R' stands for Racing.
I have EBC 'Green Stuff' fitted to my ITR (with Castrol SRF brake fluid) and they are fantastic, from cold and have never faded on me....even after doing 15 straight laps on a race circuit (braking from 175km/h @ the end of the main straight!).
Checkout the following related links -
http://www.ebc-brakes.com/autopads.htm
http://www.castrol.com.au/castrol_00...ducts_set.html
I'm looking @ installing the Mugen: N1-ECU (with the uprated Valve Springs), Twin-loop Exhaust and maybe the 4-2-1 Exhaust Manifold as well (plus some other smaller components)....anyone have any comments on them (see the below link)?
http://www.kingmotorsports.com/produ...gra/engine.asp
Old Sep 16, 2001 | 04:03 PM
Hooch'n's Avatar
Default Re: First modification for a TYPE-R (Aussie_ITR-0239)
Intake, Exhaust, Header, Rims.
Old Sep 16, 2001 | 06:42 PM
EPGONZALEZ's Avatar
Default Re: First modification for a TYPE-R (8400-RPM)
i agree with the suggestion about upgrading the driver..is a very humbling expirience when your mugenR is pounced by nearly stock R's..hahahaha..
