2 Easy questions for YOU to answer :)
Hey everyone,
2 questions
1. how do i get rid of the annoying window rattle when its down
2. once i soundproof my door with soundbread, will i still be able to access the power window assemblies if needed? for maintenance and such..
2 questions
1. There was a post about this before. You have to remove the door panel and fix some piece of plastic or something like that. It's been posted for sure, so search for it.
2. Good question.
2. Good question.
1. What that other guy said
2. The way that I did it, you wouldn't be able to access it because I used the sound deadening material to replace the off white opaque plastic sheeting that keeps water away from the interior door panel. So the only way to access it would be to cut away the material and then use another piece of sound deadening material to cover it again.
I haven't had to access the power window assembly once in the 6 years I've owned the car, so I wouldn't worry too much. Of course you can always use the spray on sound deadening material and then reuse the orginal plastic sheet to keep water out. However, it just seems tricky because I think you'd have to remove the power window assembly to prevent the spray from gunking it up. I could be wrong as I've never done it before though...
Eighty-Nyne
Jun 6, 2009 04:04 PM
Red_EM1
14
May 11, 2004 09:31 PM
