what map sensor can i use with stock ecu and boost?
i went for a ride today and my check engine light came on when i was on my way home. i checked the code and it was 03, map sensor. i went a head and reset the ecu and it went away. i only hit about 10psi of boost, at least thats what it said on
my boost guage.
what other map sensor could i use so i won't get a check engine light while using the stock ecu? this is the first time that it has happened, but not the first time i've hit 10psi.
my boost guage.
GM 2 or 3 bar. Search here on H-T and you will find lots of info like where to buy them and evan the part numbers.
Rob
Rob
i've read about the 3 bar, but i thought you couldn't use the that one with the stock ecu? would i be able to use the GM 2 bar map sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb »</TD></TR><TR><TD CLASS="quote">i went for a ride today and my check engine light came on when i was on my way home. i checked the code and it was 03, map sensor. i went a head and reset the ecu and it went away. i only hit about 10psi of boost, at least thats what it said on
my boost guage.
what other map sensor could i use so i won't get a check engine light while using the stock ecu? this is the first time that it has happened, but not the first time i've hit 10psi.</TD></TR></TABLE>
you can only use the stock one unless you get hondata or a standalone
my boost guage.
silverbulletgsr
May 20, 2004 08:24 AM
