Intake Backfire
When i put my stock intake back on it started to backfire after i would drive for a little while is this because of a dirty filter or what. And is their anyway i can clean the filter also
backfiring through the intake could be several things. Its not your filter and if its not a cleanable one go to some parts store and get a new one. It could be that and exaust valve is stuck closed or and intake valve is stuck open. take off the valve cover and see if you see anything broken... if so fix it
. if its not that you could be running too lean. too rich and you would be backfiring through intake. Id check the valve train before anything else tho
good luck.
good luck.
code 7- TPS
code 15- Ignition Output signal
code 17- Vehicle Speed Sensor
swap out distributor and the throttle body and see if it makes a difference, plus as far as your speed sensor, see if you broke the cable, or unpluged it somehow...
dingusjt
25
Nov 18, 2002 05:37 PM
