How to install a S200 Hondata system?
Old Nov 28, 2003 | 04:11 PM
mugenintegra16's Avatar
Default help installing a s200 hondata system
i was wondering if anyone can give me any info on how to install a hondata s200 system on a already chipped p28 ecu. thanks
Old Nov 28, 2003 | 05:41 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: help installing a s200 hondata system (mugenintegra16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenintegra16 &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if anyone can give me any info on how to install a hondata s200 system on a already chipped p28 ecu. thanks</TD></TR></TABLE>
If the ECU is already chipped I'm guessing that means it is socketed. Go to http://www.hondata.com for instructions. All you do plug in the S200, removed the chip you have, and plug in a new one.
Old Nov 28, 2003 | 06:25 PM
Default Re: help installing a s200 hondata system (ActiveAero)
i looked on the hondata i site i didn't find any info on that could you poit me to where i should be looking. thanks
Old Nov 28, 2003 | 07:41 PM
RyanR's Avatar
If it's already chipped, all you need to do is solder on the 5 pin connector to the ecu motherboard and run the interface cable to the hondata box. Plug in the basemap chip and you're ready to go.
Old Nov 29, 2003 | 06:05 PM
AzG35's Avatar
Default Re: help installing a s200 hondata system (RyanR)
That is only if your ECU has been socketed. If the ecu was chipped and the chip was soldered into place, you have to remove the chip by desoldering it and solder the socket in. And you have to install the 4 pin interface plug as well.
Old Nov 29, 2003 | 07:42 PM
Rob Dizzle's Avatar
first off, what have you had done?
when u say chipped, do u mean that a new fuel table has been installed onto the ecu?
what parts do you have ?
have u bought the hondata setup already?
Old Nov 30, 2003 | 03:02 PM
Champ R's Avatar
Default Re: help installing a s200 hondata system (Bob-DC2)
What exactly needs to be done on say a stock 98 ITR ecu, for hondata to be implimented?
Old Nov 30, 2003 | 03:23 PM
AzG35's Avatar
Default Re: help installing a s200 hondata system (Champ R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Champ R &raquo;</TD></TR><TR><TD CLASS="quote">What exactly needs to be done on say a stock 98 ITR ecu, for hondata to be implimented?</TD></TR></TABLE>
You cannon use a OBD2 ECU for Hondata, it must be run on a OBD1 ecu. So you would need to get a OBD2a-OBD1 conversion harness, an OBD1 ecu like a P28, and the hondata unit.
AzN_Flava
Engine Management and Tuning
Sep 15, 2017 10:33 PM
1998GsRIntegra
Aug 25, 2010 07:56 PM
EJ8 GSR-T
Oct 29, 2006 08:46 AM
b18c5GT2871R
May 1, 2006 06:10 PM
DBallz
Jul 23, 2003 11:54 AM
