Hondata Owners
Old Jul 23, 2003 | 09:18 AM
DBallz's Avatar
Default Hondata Owners
Can I install a basic S200 with boost by myself? How hard is it? Did anybody run into any problems installing the system?
Old Jul 23, 2003 | 09:19 AM
InfamousRS's Avatar
Default Re: Hondata Owners (DBallz)
If you know how to chip a ECU you will have no problem with Hondata. Its not hard, you will need a decent desoldering and soldering iron.
Old Jul 23, 2003 | 09:20 AM
PM-Performance's Avatar
all you do is plug one little plug form your ecu to you hondata box and its done .
Old Jul 23, 2003 | 09:22 AM
InfamousRS's Avatar
Default Re: Hondata Owners (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">all you do is plug one little plug form your ecu to you hondata box and its done .</TD></TR></TABLE>
a bit more to it than that...
Old Jul 23, 2003 | 09:28 AM
Default Re: Hondata Owners (InfamousRS)
i didnt know he was tlaking about chipping the ecu and what not , still not very hard if you know how to solder
Old Jul 23, 2003 | 09:32 AM
DBallz's Avatar
Well my ecu is already chipped and I have the S200 with boost. Matter fact the P28 I have has the OBD II connector so I don't need the wire hareness. But what about the push button and shift light how hard is that?
Old Jul 23, 2003 | 09:36 AM
grndcont's Avatar
thats all pritty entrylevel stuff. and your unit should have come with instructions, but if you are doubting your ablity, it might be worth it to have a dealer do it.
Old Jul 23, 2003 | 09:37 AM
BROOD's Avatar
The push button and 3step control plugs directly into the Hondata interface box (external the ECM) not difficult at all.
Old Jul 23, 2003 | 10:06 AM
DBallz's Avatar
Default Re: Hondata Owners (SLPR)
what about the shift light LED?
Old Jul 23, 2003 | 10:19 AM
ladysman's Avatar
Just in case this may help. It really is pretty easy. The chipping of the ECU is the hardest part IMO.
https://honda-tech.com/zerothread?id=458080
Old Jul 23, 2003 | 11:54 AM
DBallz's Avatar
Default Re: Hondata Owners (ladysman)
Thanks dawgs your the ant
EJ8 GSR-T
Oct 29, 2006 08:46 AM
b18c5GT2871R
May 1, 2006 06:10 PM
B16Civic93
Feb 17, 2005 08:54 AM
99B16Si
Sep 29, 2004 06:53 AM
mugenintegra16
Nov 30, 2003 03:23 PM
