HELP, engine misfiring!
Old Sep 15, 2001 | 08:33 PM
fluke702's Avatar
Default HELP, engine misfiring!
My check engine light came on and my codes are 72, 74., which means cyl 2 and cly 4 had a misfire. I heard the misfire when I started the car, and that's the only time it sounded funny. Now it runs normally. Should I just reset the ECU? I really don't want to take it to the dealer for fear of being screwed in the a$$. I was going to replace the wires and plugs anyway. Should that be good enough? Thank you to anyone who responds.
Old Sep 16, 2001 | 06:20 AM
Jared's Avatar
Default Re: HELP, engine misfiring! (fluke702)
How many miles on the engine? Sounds like it's time for an ignition tune up(cap, rotor, wires, plugs)
Old Sep 16, 2001 | 11:44 AM
ringgold's Avatar
Default Re: HELP, engine misfiring! (Jared)
If you have that code it must be an obd2 car or ecu. Sometimes on these cars they have I think IPT injectors they can stick when first fired up and also I have heard that the crankshaft fluctuation sensor can sometimes pick on current from the alternator and make it through that code when the car is first fired up. My friends car did the same exact thing last week all we did was change the plugs, run some techron gas treatment stuff, and reset the ecu.
Old Sep 16, 2001 | 12:05 PM
fixhondas's Avatar
Default Re: HELP, engine misfiring! (ringgold)
What year is this thing?
Old Sep 16, 2001 | 02:21 PM
fluke702's Avatar
Default Re: HELP, engine misfiring! (fixhondas)
It's a '97. I found out that two of the plug wires were a little loose so I pushed it in all the way. Hopefully that was the problem. Does anyone know what the security code is for my radio?
Old Sep 16, 2001 | 09:52 PM
976's Avatar
976
New User
Ignition System
Fuel Supply System
EGR System
IAC Valve
Contaminated Fuel
Lack of Fuel
Valve Clearance
Fuel Injector Circuit
Low Compression
Could be any one of these problems. In either cylinder or thereof.
Use http://www.hondaprelude.to/articles/mil_check.html as a good source.
Old Sep 16, 2001 | 09:54 PM
976's Avatar
976
New User
Default Re: HELP, engine misfiring! (B21A)
To get the code for your radio you need to talk to a honda stealership...
Old Sep 17, 2001 | 01:49 PM
fixhondas's Avatar
stealership - LMFAO
If it is a 97 with less than 150,000 miles on it- take it to a dealership and they must fix it for free unless you have modded the **** out of it. This is part of the lawsuit settlement with CARB for improper misfire monitoring.
[Modified by fixhondas, 11:27 PM 9/17/2001]
Old Sep 24, 2001 | 08:27 AM
jebarco1's Avatar
New User
i would replace those NGk's and wires with some preformance stuff, and cap also. Hey if you washed you engine in the last week maybe you got water down in the cap or the OHC spark plug holes. Common problem with engine cleaning fedisha.lol later
accordf22vtec
Apr 16, 2020 09:30 PM
teg01type-r
Jun 14, 2008 10:09 PM
r1mshady
Jun 27, 2006 05:39 PM
Cold Fyre
Jun 27, 2006 03:26 PM
busterray
Jun 23, 2003 12:03 PM
