bad alternator???
Old Nov 28, 2003 | 09:00 AM
speed_racer012's Avatar
Default bad alternator???
okay here is the problem. I just got my D15 vtec swap done and back from the shop, whenever I drive it the battery light flashes on and off and then sometimes when I stop to fill up with gas or something I can't start the car back up for a while.
Then when It does start to turn over it cranks VERY slowely. Its the same battery and alternator from my zc so they are both used. I was going to take my alternator to the auto shop and have it checked later today.
Old Nov 28, 2003 | 09:02 AM
BAZ's Avatar
BAZ
Default Re: bad alternator??? (speed_racer012)
Sounds like your alternator. Same symptoms I had when my alternator went out.
Old Nov 28, 2003 | 02:47 PM
Default Re: bad alternator??? (BAZ)
Well the alternator and the battery where perfectly fine I spent all that 10 mins taking off the stinking alternator!!! so what now maybe a bad ground wire? Well I'll check it tomorrow so I don't FREEZE my butt off.
Old Nov 28, 2003 | 02:50 PM
noslude93's Avatar
on your alt check the bolt make sure they are tight on the bottom and top. That was my problem. good luck !
I think its a power wire?
its right beside your plug.
Old Dec 3, 2003 | 04:45 PM
Default Re: bad alternator??? (noslude93)
okay could my starting problem be that I have a bad ground going from the - battery terminal? When I went to jump it the ground sparked and then I put the - clamp where the wire is bolted onto the block and it started to turn over and then slowely started because my battery is pretty much dead.
I tightened my alternator so the belt is tight. It was really loose the other day. almost falling off.
Old Dec 3, 2003 | 05:26 PM
Oh well I guess it doesn't really matter about that ground because I'm gonna replace it anyway.
Old Dec 6, 2003 | 04:18 PM
okay same thing but I don't know if it's acutally the problem. I was driving down the road today and my battery started sputering and then my car just lost all it's power and died. Now the question. could that have happend because of a bad battery ground and made it not charge and go dead? Like I said before I had the alternator and the battery checked and everything seemed to work just fine.
Also I put the new cable on and it started right up(starting problem solved) but then after it started it started going crazy and the lights started flickering on and off then it just died. is that because of not having a ground also?
Old Dec 6, 2003 | 04:51 PM
skrappy's Avatar
the way to check if your alternater dosent work is first start the car the disconect the ground cable with the car on if it turns off your alternater dosent work
Old Dec 6, 2003 | 06:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed_racer012 &raquo;</TD></TR><TR><TD CLASS="quote"> Like I said before I had the alternator and thebattery checked and everything seemed to work just fine. </TD></TR></TABLE>already checked.
Old Dec 6, 2003 | 07:01 PM
Anybody else? thats all thats keeping me and my car from having a little bit of fun.
Old Dec 6, 2003 | 08:10 PM
Jimmy's Avatar
Global Moderator
go to autozone and get them to test your alt and your battery...goodluck
Old Dec 7, 2003 | 09:48 AM
Default Re: (USDMDC2)
I ALREADY HAD ADVANCED AUTO TEST IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1
Old Dec 7, 2003 | 11:34 AM
HatchBox's Avatar
Skoobie no more...
Default Re: (speed_racer012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed_racer012 &raquo;</TD></TR><TR><TD CLASS="quote">I ALREADY HAD ADVANCED AUTO TEST IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1</TD></TR></TABLE>
ok...and what did they say?
Old Dec 7, 2003 | 11:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">go to autozone and get them to test your alt and your battery...goodluck</TD></TR></TABLE>
I had it checked and it was fine. I don't know about were they are from but the people at Auto Zone here in Wichita, Ks are some of the Dumbest 16 17 year olds out there and don't even know how to check the alternator(I went there to have it done once) but at advanced auto the guys own-drive-work on their own hondas, acuras, and mitsubishis(sp I hate that name) and know more.
Old Dec 7, 2003 | 12:26 PM
HatchBox's Avatar
Skoobie no more...
Default Re: bad alternator??? (skrappy)
did u try this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrappy &raquo;</TD></TR><TR><TD CLASS="quote">the way to check if your alternater dosent work is first start the car the disconect the ground cable with the car on if it turns off your alternater dosent work </TD></TR></TABLE>
Old Dec 7, 2003 | 01:21 PM
guttedsilvercrx's Avatar
Default Re: bad alternator??? (ind3ciso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso &raquo;</TD></TR><TR><TD CLASS="quote">did u try this?
i just tried that cuz im having problems too and after i disconnected the ground the car didnt quit but the rpms dropped and i turned my low beams on and it quit immediatly...bad alt?? if so how much do they run to get a new one?
Old Dec 7, 2003 | 02:14 PM
underESTIMATED's Avatar
Default Re: bad alternator??? (guttedsilvercrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guttedsilvercrx &raquo;</TD></TR><TR><TD CLASS="quote">
i just tried that cuz im having problems too and after i disconnected the ground the car didnt quit but the rpms dropped and i turned my low beams on and it quit immediatly...bad alt?? if so how much do they run to get a new one? </TD></TR></TABLE>
$150 is the typical price.
Old Dec 7, 2003 | 03:00 PM
HatchBox's Avatar
Skoobie no more...
if u want i have one off my d15 u could have for cheap. works great
Old Dec 7, 2003 | 09:33 PM
skrappy's Avatar
well i can get one for like 35$ rebuilt with 90 days warranty in souther cali compton were do u stay at
Old Dec 8, 2003 | 04:45 AM
Well I changed the the - cable and grounded it good and it starts right up and keeps running strong.
The End
And yes I did try that. I guess it would have helped if I could have changed the title to let everybody know that the alternator was fine.
meterus
Feb 10, 2011 03:00 AM
eggie75
Mar 25, 2010 04:37 PM
levison
Jan 5, 2008 12:11 PM
EG6R
May 10, 2007 01:57 PM
Slammed Ek9
May 2, 2005 12:06 PM
