To those with Walbro intank fuel pumps...please read...
Old Nov 27, 2003 | 11:20 AM
JDubya's Avatar
Default To those with Walbro intank fuel pumps...please read...
1) Are they suposed to come with a sort of wire harnes that clips into their pump, then into the stock integra wire clip? or does the stock wire clip plug right into the Walbro?
2) Is there something that's suposed to hold the filter on? like a retainer or something, mine doesn't have one. Thanks.
Old Nov 27, 2003 | 11:31 AM
XSSIVE's Avatar
Default Re: To those with Walbro intank fuel pumps...please read... (ALL MOTOR LS)
i just did a walbro 190lph in my teg last night...the previous owner of the car had a 255lph high pressure in the car and it is an all motor car DOH....too high fuel pressure, causing problems...that's why i switched it. anyway, the plug seems like the stock one in the tank, i don't think this guy changed it, it's too neat a job with retaining clips and such. so i think it uses the stock plug...sorry i'm a bit vauge about that but i don't want to give you the wrong answer since mine was tampered with before. as for holding the filter on, there is a tiny tiny little silver clip, it is a small little ring, it looks like a washer that flares up into a dome at the top that holds the filter in place on the plastic pin on the bottom of the pump. check your package, it is tiny and i missed it at first. now, be careful with the little plastic tab that it goes on, i dropped my pump and just my luck that tab broke a bit, not fully off but dangling...so i used a bit of super glue on it then put the retaining ring on and then doused it with enough super glue to hold a house down hahaha. hope that helps..
-Mike
Old Nov 27, 2003 | 01:16 PM
citrus3000psi's Avatar
Im not sure how the Walbro would be causing too much fuel pressure since thats what u have a fuel pressure reg for...There is a return line to the gas tank...so obviously there isn't 255 liters of gas going into your car per hour constantly it gets sent back to the gas tank...
Old Nov 27, 2003 | 02:31 PM
SiR831's Avatar
Default Re: (citrus3000psi)
i have one in my EG and the stock harness plugged right up. But on my EF i believe i had to solder the harness (wasn't plug and play).
Old Nov 27, 2003 | 03:09 PM
TurboTeG4's Avatar
Default Re: (SiR831)
Chk your bag good I missed the retainer clip at first but its in the filter bag.
Old Nov 27, 2003 | 05:51 PM
JDubya's Avatar
Default Re: (TurboTeG4)
that the thing, i got it used so there is no bag... Is there something that I could use to rig it?
Old Nov 27, 2003 | 06:20 PM
TurboTeG4's Avatar
Default Re: (ALL MOTOR LS)
I also bought mines used and was wondering how i was goin to hold that filter on there myself before i took a better look
bump
Old Nov 27, 2003 | 07:19 PM
AP-Signworks1's Avatar
But with the 255 high pressure pumps, it will cause a richness at idle with the factory fuel pressure regulator. Factor FPR is designed to work with a factory fuel pump at a certain pressure/flow. The 255 flows more than that obviously so it will throw off the factory fpr. It doesn't self adjust as far as I know, so the car will run rich.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure how the Walbro would be causing too much fuel pressure since thats what u have a fuel pressure reg for...There is a return line to the gas tank...so obviously there isn't 255 liters of gas going into your car per hour constantly it gets sent back to the gas tank...
Old Nov 27, 2003 | 08:01 PM
XSSIVE's Avatar
Default Re: (AP-Signworks1)
Bingo...you got that right AP...with a 255 high pressure pump and my b&m add on regulator the car would not come off of a 60psi idle which is insane...this is due to the high pressure of the pump. no add on fuel regulator could get it lower only a full unit like an aeromotive could have. there was no need for this pump in my car and caused more problems than anything....lesson here is bigger is not allways better!!
-Mike
RoadRaceMike
May 10, 2011 12:38 PM
pjr710
Apr 3, 2010 05:59 PM
Sanbon
Honda Civic (2001 - 2005)
Apr 3, 2008 10:30 AM
DOHCgarage919
Jul 12, 2007 12:46 PM
twofive
Jan 1, 2006 10:28 AM
