Koyo or fluidyne?
Honda-Tech Double Platinum Member
Whats up people...its been a while since ive posted in here. Anyway i just ordered a jimfab x-member and im looking to get a new radiator too. Fluidyne is a little cheaper, but not enough to warrant me choosing it over koyo. The koyo is 53mm thick and if i remember correctly i think that the fluidyne is 36-38 or something. Im also looking to get a new lower degree thermostat and a new radiator cap...what are your suggestions for both? And if any of you know of a better or cheaper radiator(besides stock)...let me know. OK heres my stats. Its a 90 crx with a b18a(HASport billets), custom turbo kit with revhard mani and t3/to4e, and the jimfab bar. Theres alot more but i just named the things that relate top the radiator because if space and everything. Thanks
PS-where is the cheapest place to buy all this ****?
Sean
Sean
If you have a turbo I would get a half sized radiator. C&R makes one that bolts right in.
As for themostat Autozone sells some low temp ones for like $11.
For radiator cap Spoon makes the highest pressure one at 1.35bar and is about $30. Some people say the extra pressure will make your hoses blow out or some crap but I've had mine for months and its been fne. I have an all-metal CSF radator with new hoses and band clamps on those hoses instead of that stock crap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">If you have a turbo I would get a half sized radiator. C&R makes one that bolts right in.
</TD></TR></TABLE> Where is the cheapest place to get a C&R at?
http://www.absoluteradiator.co...rod=9
Check out the High Performance All-Metal radiator. Its twice as thick as the stock unit, and still fits in the factory location. If it will fit in front of your turbo, I would definately get this.
Sorry i forgot to mention that im getting a eg rad. The car is already turbo'd...i just wanted more room up there. Thanks for the link and info....keep it coming.
Sean
Sean
i have a half size koyo radiator and flexalite slim fan. i have about 5.5 inches clearance in front of the#4 runner, if that gives you any idea how much room you would have if you kept a full sized one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi »</TD></TR><TR><TD CLASS="quote">i have a half size koyo radiator and flexalite slim fan. i have about 5.5 inches clearance in front of the#4 runner, if that gives you any idea how much room you would have if you kept a full sized one</TD></TR></TABLE>
Is this half size like the EG one is? Does it bolt right in? If so where can you get that?
I think im just going to get the koyo. C&R's are nice but they are just too damn expensive. Thanks for all the help.
Sean
Sean
Is this half size like the EG one is? Does it bolt right in? If so where can you get that?</TD></TR></TABLE>
sorry its the EG one and i have a place racing crossmember to fit it
