how to put battery in a b16/ef civic?
Old Nov 26, 2003 | 08:02 PM
drew2's Avatar
Default how to put battery in a b16/ef civic?
battery tray doesn't fit b/c the clutch cable bracket sticks up about an inch too high. i can't move the clutch cable w/out putting a sharp bend in it. how have other done this?
Old Nov 26, 2003 | 08:24 PM
85mm LsVTEC's Avatar
Default Re: how to put battery in a b16/ef civic? (drew2)
Relocate the battery to the back of the car.
Old Nov 26, 2003 | 08:37 PM
Redline130's Avatar
What kind of mount kit are you using? I haven't heard too much about this sort of problem before.
Old Nov 26, 2003 | 08:44 PM
guttedEF's Avatar
I wouldn't recommend relocating to the back of the car, that is unless you don't plan on going to the track. If you relocate your battery from the engine bay, you have to have an external power switch that kills ALL power to the car.
Might wanna see about getting a smaller one, like an Odyssey battery. I have one in my hatch and it fits perfect. I wish I had a pic, but basically, it's about 1/4 the size of the stock battery. Starts the car fine every time, even with my alarm.
Old Nov 26, 2003 | 08:46 PM
^jefs0ng's Avatar
Banned
Default Re: (guttedEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guttedEF &raquo;</TD></TR><TR><TD CLASS="quote">If you relocate your battery from the engine bay, you have to have an external power switch that kills ALL power to the car.
can you explain this please? I have my battery in the back.. came like it.. no one told me anythign about external power...
Old Nov 26, 2003 | 09:16 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (.jefs0ng)
Spoon makes a really small battery.
Old Nov 26, 2003 | 09:29 PM
biggdogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .jefs0ng &raquo;</TD></TR><TR><TD CLASS="quote">
can you explain this please? I have my battery in the back.. came like it.. no one told me anythign about external power...</TD></TR></TABLE>
same here , i never had anyone say anything to me at the track .
Old Nov 26, 2003 | 10:39 PM
Built B16A's Avatar
Default Re: (biggdogg)
not external power.. a switch.. a cut off.. for fire saftey perposes...
i dont' think its a requirement... but im sure in some drag classes, they require it.. but for 10 seconds and up.. you'll be ok...
whata smuck..
Old Nov 27, 2003 | 07:39 AM
raene's Avatar
Default Re: (Built B16A)
The track officials should be checking to see if you have a power cutoff switch easily accessible and visible from the rear of the car. You also need a vented battery box around the battery. I'm not sure if that holds with dry batteries but I know it's true with the wet types.
Old Nov 27, 2003 | 07:45 AM
onePOINTsix's Avatar
Default Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">The track officials should be checking to see if you have a power cutoff switch easily accessible and visible from the rear of the car. You also need a vented battery box around the battery. I'm not sure if that holds with dry batteries but I know it's true with the wet types. </TD></TR></TABLE>does anyone know haw to vent the battery without a special box? i know it's been done before but i dont know where the battery vent is so i can run a hose from it to the outside of the car
Old Nov 27, 2003 | 09:38 AM
type Gendy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew2 &raquo;</TD></TR><TR><TD CLASS="quote">battery tray doesn't fit b/c the clutch cable bracket sticks up about an inch too high. i can't move the clutch cable w/out putting a sharp bend in it. how have other done this?</TD></TR></TABLE>
If its just the battery tray that's getting in the way, dont use it. That was my problem and i have been fine for 11 months now.
Old Nov 27, 2003 | 09:50 AM
FourthGenHatch's Avatar
I have my battery in the back and when I went to the track they never said anything about it.
Also just get a sealed battery because than you don't have to vent anything.
Old Nov 27, 2003 | 09:58 AM
raene's Avatar
Default Re: how to put battery in a b16/ef civic? (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">I have my battery in the back and when I went to the track they never said anything about it.</TD></TR></TABLE>
That just means the official was lax in checking the car. A lot of times they just do a perfunctory check of my car because I don't run in the 11s or 12s, but sometimes you get an official that will check EVERYTHING. And if you're not to spec, you're not racing. I do everything by the book so I don't have to be worried about being kicked out
Old Nov 27, 2003 | 12:40 PM
Built B16A's Avatar
Default Re: how to put battery in a b16/ef civic? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">but sometimes you get an official that will check EVERYTHING. And if you're not to spec, you're not racing. </TD></TR></TABLE>
Word to your mother, some times i would go through tech, and not even have to pop my hood, or show registration.. and sometimes, ide have to do everything.. i always got busted and had to coff up my nitrous bottle, for no blow down tube, or having the 2 bottle tied down securely. ( after that, i snuck them in with a spectator )
Old Nov 30, 2003 | 04:15 PM
guttedEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">not external power.. a switch.. a cut off.. for fire saftey perposes...
whata smuck..</TD></TR></TABLE>
That's what I said, an external power cut off switch, killing all power. I honestly haven't read the book, so I don't know the leagality of it. But I'm a regular at out track and know the techs and officials. When I asked what I'd need to do if I moved it, they told me about the switch. Some tracks are more slack than others. When I was in GA, they did'nt check much usually. At the local track here in Phoenix, they are usually pretty thorough, but not "nit-picking" things. Kill switches, removed hub caps, missing lugs, batter tie downs.. just the usuall important stuff.
fastrider213
Sep 19, 2009 11:53 AM
efgarage
Nov 13, 2005 02:22 PM
coupon
Jul 6, 2005 08:14 AM
.bagged
Feb 12, 2004 08:05 PM
drew2
Jan 11, 2004 05:01 AM
