Front upper balljoint -89 Accord
Old Nov 26, 2003 | 04:07 PM
POS's Avatar
POS
Default Front upper balljoint -89 Accord
Does the whole upper control arm need replaced or can the balljoint be replaced by itself?
edit - I searched and found that it looks like its best to replace it. Can I get by with re-using the old control arm bushings?
Thanks.
Old Nov 26, 2003 | 04:31 PM
96hatch96's Avatar
Default Re: Front upper balljoint -89 Accord (POS)
you can change the ball joint itself.. no need to waste money on a hoopty..
Old Nov 26, 2003 | 04:51 PM
89_LXi's Avatar
Default Re: Front upper balljoint -89 Accord (96hatch96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hatch96 &raquo;</TD></TR><TR><TD CLASS="quote">you can change the ball joint itself.. no need to waste money on a hoopty..</TD></TR></TABLE>
You can't get just the balljoint, gotta buy the entire control arm with the balljoint already in it. Runs about $70-85 aftermarket, $100 something from Honda. I would definitely replace the bushings while it's out... they're cheap, might as well. Of course you could also switch out (assuming you're talking about the fronts) the Accord arms with 2nd gen Prelude (84-87) upper arms, which not only have seperate replacable balljoints, but will also give you camber adjustments to play with (such as if you lower your car). They're a nearly direct swap in.
Old Nov 26, 2003 | 05:40 PM
2+2=5's Avatar
Default Re: Front upper balljoint -89 Accord (89_LXi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_LXi &raquo;</TD></TR><TR><TD CLASS="quote">
You can't get just the balljoint.</TD></TR></TABLE>
1) they dont just sell them like that
2) you gonna need a hyd. press to get it out.
gonna love those modified Mcpherson strut design.
Old Nov 26, 2003 | 05:49 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS &raquo;</TD></TR><TR><TD CLASS="quote">Can I get by with re-using the old control arm bushings?
Not unless you can figure out a way to get them out without destroying them.
Old Nov 26, 2003 | 11:24 PM
POS's Avatar
POS
Thanks.
I can get the control arm for $55 with a friend's discount at Autozone.
Is there anything special needed to press the bushings into the control arm. I'm talking about the control arm bushings.
Old Nov 27, 2003 | 06:00 AM
Chiovnidca's Avatar
Default Re: (POS)
Is there anything special needed to press the bushings into the control arm. I'm talking about the control arm bushings.</TD></TR></TABLE>
Just grease em up real good and push them in.
Old Nov 27, 2003 | 08:21 AM
89_LXi's Avatar
Default Re: Front upper balljoint -89 Accord (2+2=5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">
They're not modified MacPherson strut design.... anything MacPherson modified or unmodified, still uses the top of the strut and a strut bearing as the upper pivot point for the steering knuckle (no upper control arm). Only way a modified MacPherson is different from an unmodified is that the spring isn't mounted in the strut. 3G Accords use SLA (short over long arm) suspension.... no struts involved.
Just wanted to clarify
Old Nov 27, 2003 | 01:50 PM
DJPRIMO's Avatar
You have to get the whole control arm,i recently had to replace mine (1992 honda accord ex).
zx12ryder
Oct 9, 2008 02:24 PM
dtran002
Nov 11, 2007 10:56 AM
jayshonda
Nov 21, 2004 05:29 AM
huyvu90
Oct 28, 2004 06:33 AM
lysol
Apr 27, 2004 10:41 AM
