How to make a trubo GSR faster?
Old Sep 14, 2001 | 09:23 PM
MintyDip's Avatar
Default How to make a trubo GSR faster?
i dont know too much about turbos, but say if I had a turbo GSR......say drag 3 kit
drag 3 kit on stock G3 gsr..........how much power?
what to do to make faster?
Old Sep 14, 2001 | 10:47 PM
Anthony K's Avatar
New User
Default Re: How to make a trubo GSR faster? (MintyDip)
I'm not an expert...to be honest, I'm pretty new at car mods, but I'd think that you'd wanna build up the block to tolerate more psi from the drag kit in order to make more horsepower. A Jackson racing supercharger on a gs-r at 6psi puts out about 200-220 whp I believe, so the drag 3 kit will probably put out slightly more on a stock engine at 7psi.
Old Sep 14, 2001 | 10:52 PM
OneThirtyEight's Avatar
Default Re: How to make a trubo GSR faster? (GS-R916)
inject some nitrous into the IC heh j/k but that does help to cool it down.
Old Sep 14, 2001 | 10:53 PM
MintyDip's Avatar
Default Re: How to make a trubo GSR faster? (97blackteg)
really?
u can injst nitous to the IC to make it cooler? and its safe?
never knew that
Old Sep 14, 2001 | 10:56 PM
I dunno about that, I was just messin around, but I have heard that somewhere. I think there is some truth to it. Ask on FI board.
Old Sep 14, 2001 | 11:31 PM
PureTeg420's Avatar
Expect around 260whp @ 8psi with minor tuning for a GSR
Old Sep 15, 2001 | 06:29 AM
stick's Avatar
first stronger rods and lower compression pistons
big injectors >550 and up
big 3" cat back exhaust
stand alone FMU
EBC
and stronger clutch, stiffer susp,etc....
easily boost at 12 psi with this set up or higher up to 18 or 20 psi
Old Sep 15, 2001 | 06:33 AM
bigTom's Avatar
Default Re: How to make a trubo GSR faster? (stick)
stand alone FMU
EBC
U D0NT NEED LOWER COMPRESSION PISTONS! 10:1 will do just fine anything lower will just give u lag
Old Sep 15, 2001 | 07:39 AM
Speedz's Avatar
Default Re: How to make a trubo GSR faster? (ek9t)
actually, some racers SPRAY, not inject, Nitrous on their Intercooler right before pulling up to the staging lights to cool their intercooler down even more which cools the air inside before the car gets going fast enough for the air to blow through the intercooler to make a difference. this really helps on hot days.
i've seen this tip in a couple of import performance magazines.
http://kos.realns.com/integra.html
Old Sep 15, 2001 | 11:19 AM
Type S's Avatar
stock gsr @ 6psi with a drag kit 220whp-230whp.
you want more power, you can get crower rods, je 10:1 comp pistions or 9.5:1. rc 440 injectors, paxon fuel pump. and then you can turn the boost up to 15psi or more
Old Sep 15, 2001 | 12:15 PM
Eeepers's Avatar
New User
Default Re: How to make a trubo GSR faster? (Type S)
Ignition upgrade, and intercooler would help too.
thino
Jul 14, 2006 05:51 AM
Hayaimoto
Apr 26, 2005 10:40 PM
Turbo D17
Oct 10, 2002 12:41 PM
phear
May 7, 2002 08:55 PM
IgniteTeg
Aug 4, 2001 09:53 PM
