89 Si fuse box help..
From: hittin corners so hard you can taste my rims..
this is the deal.. i need help. one day my battery blew up, and well, wiped out mainly everything electrical. now im trying to put the peices back together..
can anyone tell me what this one wire, goes too? its out of place, and i don't see it on my new harness. does it come out of the bundle of wires with the chassis to engine changeover, near the wirring that leads to the headlights? can anyone guess what that 1 wire is for? weird.
and, this is the extreme lower of the fuse box, can anyone clarify which is the battery lead.. i belive its the one that is showing most of the wire.. the other being power lead to the engine harrness..
thanks guys..
thanks guys..
i just took another peak at it.. and that lower, 15A wire says ECU on the new fuse box.. but, this is the thing, im converting the right side of a 91 si chassis harness on my 89 si, and i don't see that clip, on the 91 harrness.. anyone know where this wire goes? i would think ECU refference? could it be in the 89 si's chassis loom?
From: I told you to wait in the truck in Texas, United States
"no one wanna go out to they're car, and look where that wire goes for me ehh?"
I do,I do...
The white wire in question goes to the a/c clutch relay and to the condensor
fan relay located behind the passenger side headlamp..
{To verify this, I started my car and turned on the A/C then unplugged the wire}
and of course the compressor kicked out and the fan turned off
"and, this is the extreme lower of the fuse box, can anyone clarify which is the battery lead.. I believe its the one that is showing most of the wire.. the other being power lead to the engine harness.. "
You are correct there... good Luck bro!
I do,I do...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">
and of course the compressor kicked out and the fan turned off</TD></TR></TABLE>
Hrmm.. thats werid.. cuz i would think.. since, theres 4 wires to that plug, and 4 fuses inline, that the fuses would correspond. if that would be true, it would be the ECU lead, as per the listings, and it should shut down the computer.. i would venture to think.. anyone verify this?
shitballs... hahahah! the last ones missing! hahahaha
can anyone look at there fuse box, and tell me what that fuse says?
bingo.. the wire im interested, just under the ECU wire, says condensor.. and we all know 12 second honda's dont' have AC... hahaha, so im going to leave it of.
thanks guys.. thats all i needed to know.
DailyDriven259
May 11, 2012 11:31 AM
