Help: Black smoke!!!
Old Nov 25, 2003 | 08:33 PM
SleepnCiViC's Avatar
Default black smoke, help!!!!
ok guys in my ek civic i have 2000 b18c5 motor. Now when im at WOT ive noticed black smoke coming out of the exhaust. Ive been told it could be a bad cat (ihave the factory civic cat and exhaut w/ 96k miles on it) Or what else could it be?? let me know asap guys
Old Nov 25, 2003 | 08:34 PM
laughinxxx's Avatar
New User
Default Re: black smoke, help!!!! (SleepnCiViC)
running rich
Old Nov 25, 2003 | 08:40 PM
how would i go about correcting the prob, also is runnin a lil rich good, im sure it cant be good if im putting out black smoke though.
but anyway im sure its not ideal to be blowing out smoke so how can i fix the prob
Old Nov 25, 2003 | 08:55 PM
laughinxxx's Avatar
New User
Default Re: (SleepnCiViC)
Grab a VAFC, Hondata, etc and get tuned with a wideband O2. I run an H22, so black smoke if just a fact of life.
Old Nov 25, 2003 | 09:04 PM
ok well your saying an eninge managment system is the only way to correct it. Ok well if that is, i dont have the funds for that ASAP. someone said it was burning oil but it def doesnt smell that way and if that was the case it would be bluish white smoke correct? So anyway wil it running rioch and blowing out some black smoke be nessecarly harmful??
B2FiNiTY's Avatar
Could be a bad 02 also.
Old Nov 25, 2003 | 09:10 PM
how can i tell if the o2 is bad?? would it throw a code, the check eng light hasnt come on
Old Nov 25, 2003 | 09:11 PM
laughinxxx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">So anyway wil it running rioch and blowing out some black smoke be nessecarly harmful??</TD></TR></TABLE>
Not really. Might foul a few plugs out, but that's unlikely and a cheap fix.
Old Nov 25, 2003 | 09:14 PM
foula few plugs out, what do you mean??
Old Nov 25, 2003 | 09:19 PM
DsITR's Avatar
The black smoke is most likely unburnt fuel. The unburnt fuel results in carbon build up on the plugs..which inturn *fouls* them, basically they don't spark ideally.
the majority of hondas run rich to prevent pre-detonation/ignition..
It's not ideal, but its alot safer for your motor this way. Running lean is much worse. I wouldn't be too concerned about it.
Old Nov 25, 2003 | 09:27 PM
ok also my car has a jittery ideal the rpms seem steady but there is a vibration do you think this to could be from the "foul' plugs
Old Nov 25, 2003 | 09:29 PM
DsITR's Avatar
jittery idle? but the rpm's stay constant?
if the rps are constant, it isn't your idle....do you just mean @idle certain things in your car vibrate? ie shiftknob, steering wheel etc?
you have b18c5 in a civic correct?
Old Nov 25, 2003 | 09:32 PM
yeh b18c5 in a civic, the rpms appear to be steady, but the motor literally jitters, i can see it and feel itin side the car. Possibly the mounts?? or is somein such as the plugs cauing this
Old Nov 25, 2003 | 09:34 PM
DsITR's Avatar
If your rpms stay constant, it is most likely more of a mount/stabilizing issue than plugs, etc. (anyone else w/more expertise than me please chime in)
FYI in my 97 ITR the shift **** does *buzz* a bit..same thing in my Prelude, yet not as noticeable.
as long as you aren't hearing any audible/visual(ie CEL) warning signs, and you don't notice any hesitation in the motor it is probobly running fine.
keep in mind you a driving a swapped honda, not BMW a few vibrations are a normal thing.
Old Nov 26, 2003 | 12:53 PM
laughinxxx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">yeh b18c5 in a civic, the rpms appear to be steady, but the motor literally jitters, i can see it and feel itin side the car. Possibly the mounts?? or is somein such as the plugs cauing this</TD></TR></TABLE>
Motors vibrate. It's ok. Those pistons are moving at insane speeds. If you have aftermarket mounts, then you will really feel the motor in the car. It's normal. If you are worried about fouled plugs, pull them for an inspection. If they are solid black then they are fouled or about to be. If they are a light tan color, then you're fine.
Old Nov 27, 2003 | 08:58 AM
ok ill try doin that after i eat some turkey today!!
joehonda1129
Nov 29, 2007 02:35 PM
kodarren
Sep 14, 2006 07:44 PM
Fobstylez
May 31, 2005 11:54 AM
suckanut
10
May 14, 2005 04:10 PM
99shRIGGS
Dec 29, 2004 08:49 PM
