help please: first startup, motor runs rough and nothing happens when press gas pedal
Old Nov 25, 2003 | 03:07 PM
mykem's Avatar
Default help please: first startup, motor runs rough and bogs out, distributor problem, PICS added
okay, tonite was my big night to try starting my new engine, i got the motor to start, but it runs rough, and nothing happens when i press the gas pedal (no increase in revs, motor just kind of bogs), i think maybe i have the spark plug wires wrong, could someone please let me know how to arrange them (a picture is worth a thousand words)
this is a 1998 civic dx motor, and i am using a 91 civic si distributor for my mpfi swap, it had a different motor that ran fine in there before with the mpfi, so i know its not an issue with that
if anyone can give me some ideas to try, and post some pics of distributor spark plug wire arrangement, thanks
Modified by mykem at 1:10 AM 11/26/2003
Old Nov 25, 2003 | 03:11 PM
onePOINTsix's Avatar
Default Re: help please: first startup, motor runs rough and nothing happens when press gas pedal (mykem)
make sure the white wires on the dizzy are right, any codes? quadruple check your wiring, the spark plugs wires on the dizzy sould be
3-4 ---Top of cap
2-1 ---Bottem of cap
Old Nov 25, 2003 | 04:07 PM
mykem's Avatar
Default Re: help please: first startup, motor runs rough and nothing happens when press gas pedal (Sideout)
okay, i tried that order 4 times, in every position, and it wouldn't run, below pics are the only combination where it starts and runs, but nothing happens when gas pedal is pressed
i know all the wiring is correct, because the previous motor ran fine with the mpfi, so i just need to get this timing/distributor issue solved, do i need to rotate the distributor to sit how it was on the old engine?
please check these pics:
Old Nov 25, 2003 | 05:02 PM
redeyeef2's Avatar
you have your distributor installed incorrectly. rotate it one post counter-clockwise and change you firing order to match.
Old Nov 25, 2003 | 05:13 PM
phatrick2332's Avatar
yea, the round part should be facing the front of the engine bay. then put ur wires back on in the correct order.
Old Nov 25, 2003 | 08:25 PM
cstem's Avatar
Default Re: (phatrick2332)
Your positive battery cable is not getting the proper charge from the thermostat housing.
Old Nov 26, 2003 | 11:30 AM
Destroyer24Seven's Avatar
Those little metal clips hold your distibutor plugs thats how you'll know when it's lined up right.
Old Nov 26, 2003 | 12:08 PM
Default Re: (Destroyer24Seven)
your dizzy is on sideways, it sould look like this
| o |
| 0| 0|
| 0 0 |
edit, the flat part should be facing up, the round part faceing down
Old Nov 26, 2003 | 12:47 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (cstem)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstem &raquo;</TD></TR><TR><TD CLASS="quote">Your positive battery cable is not getting the proper charge from the thermostat housing. </TD></TR></TABLE>
HAhaaa!
Old Dec 1, 2003 | 05:54 PM
mykem's Avatar
Default Re: (cstem)
lol: i just unhooked the battery cable to adjust the spark plug wires
anyway, i'm going to rotate the distributor around tomorrow evening, and change the plug wires to match...i hope it starts!!
thanks guys
93baggedcivic
Jun 10, 2007 06:42 PM
purplexs650d
Oct 17, 2006 12:31 PM
ThisLittleSleepeR
Sep 24, 2005 04:33 PM
89JDMcrx
10
Nov 27, 2004 07:53 PM
evilsolb16
12
Sep 6, 2004 09:11 PM
