Changing Timing Belt
Old Nov 25, 2003 | 01:51 PM
abeaujuin's Avatar
Default Changing Timing Belt
Does anyone have illustrations or pictures that explains how to properly change the timing belt on a 94 Accord EX?
Old Nov 25, 2003 | 05:10 PM
im_the_teacher's Avatar
Default Re: Changing Timing Belt (abeaujuin)
rarely people would do it your self job and do it at home job..
i done a timing belt on a 96 civic before.....is easy w/ the right tools and a lift.
anyways, if u plan to do it yourself i would get all the nessary tools, you can search on h-t to find sum member already have instruction lay outs already.
good luck..
i would not do it w/ out a lift..
Old Nov 26, 2003 | 04:18 AM
KatyHonda's Avatar
My first recommendation is buy a shop manual, Honda is best, but Haynes for this car is not bad. I have a Haynes for my daughter's 94 EX & the Honda Shop manual. My belief is informaiton is cheap and time is expensive.
Timing belt replacement is more than simple DIY, but w/i capability of any determined person w/ necessary tools. The one really tough and demanding task of this job is removing the bolt that holds the harmonic balancer/ Accessory Pulley on the crankshaft. This bolt is very tight and requires a special tool to restrain. It will sometimes, but not always, yield to a very good 1/2" or 3/4" air impact. After struggling w/ no success w/ an air wrench, I bought the special restraint tool, a Schley product. Two breaker bars, one to hold the special tool and a second to turn the crankshaft bolt are necessary. You may need a "cheater pipe" for leverage on the bolt. In one case, I had to resort to getting help from my local Honda shop, before I bought the tools.
For tips and procedure help, look at the following link.
http://www.cybertrails.com/~be....html
I hope I didn't scare you.
good luck
Old Nov 26, 2003 | 07:14 AM
abeaujuin's Avatar
Default Re: Changing Timing Belt (KatyHonda)
Thanks, but no you didn't scare me I am aware of the issue in removing that bolt. I had a shop remove it already. I just need get the steps in removing and replacing the belt with the right specs.
Thanks
Old Nov 26, 2003 | 08:08 AM
matix's Avatar
I did it twice b/c one of my seals were bad and i had to put that in a week after i did the timing belt.
Im only 18 and this was my first real work on my car. Just go buy a book and research it as much as you can and it shouldnt give you any problem. I did it with jackstands so you dont gotta have a lift. Just watch out for the crank pulley bolt its really hard to get off we broke a extension trying to break it loose.
Old Nov 27, 2003 | 05:20 AM
YeuEmMaiMai's Avatar
since you gotta take off the drive belts hoses and water pump I would just replace those items while you are at it
Old Nov 27, 2003 | 09:31 AM
chrisCNL's Avatar
im me back with your email and i'll send the PDF file of the car year...
Old Dec 1, 2003 | 04:18 AM
abeaujuin's Avatar
Default Re: Changing Timing Belt (chrisCNL)
abeaujuin@geosyntec.com
Old Dec 12, 2003 | 03:07 PM
david90's Avatar
95 accord v6. plz
double2gs@yahoo.com
Old Dec 13, 2003 | 08:26 AM
badazzaccrd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisCNL &raquo;</TD></TR><TR><TD CLASS="quote">im me back with your email and i'll send the PDF file of the car year...</TD></TR></TABLE>
Shoot, can I jump on the bandwagon
96 Accord EX - badazzaccrd@aol.com
Much appreciated! Thanks.
jaxflex
Feb 24, 2016 02:17 PM
fajerm
Jul 16, 2015 05:35 PM
stevescivic
Jul 20, 2007 05:55 AM
chibiko
Feb 22, 2007 05:45 AM
danz75
Jun 29, 2004 10:52 PM
