CHECKING ECU FOR CODES??!!
Hey peoples just have a quick but important question for all. Recently i have been having some strange symptoms for my engine...and while driving over the mountain pass my ecu decided to throw a code...but i am not sure how to EXACTLY check the ecu to make it show me the code......CAN ANYONE TELL ME THE STEP BY STEP OF HOW 2 DO THIS...starting with the location of the ecu??THNX a BUNCH
'92 Accord - he posted again in Tech. But I don't know how to do it on that year.
https://honda-tech.com/zerothread?id=688459
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knowtomorrow3001 »</TD></TR><TR><TD CLASS="quote">How do you check the ECU for codes on a 95?? Cause I took it to Autozone and they could find the plugin </TD></TR></TABLE>
If it's a v6 model, the obd2 data link connector is behind the ashtray. The service check connector should be under/behind the glove box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">95 wasn't obd2...so there wouldn't be a diagnostics behind the ashtray in that year...</TD></TR></TABLE>
The v6 model Accords were OBD2 starting in 1995. The DLC is behind the ashtray.
if it is a 92 the SCS sonnector plug is on the right of the dash under the Glove compartment. It should be covered with a green cover. Look for the two pin plug that the SCS plug.
TurboRedSi
Jul 17, 2003 10:59 PM
