Aem Cold Air System Question
Old Nov 24, 2003 | 02:34 PM
daywong's Avatar
Default Aem Cold Air System Question
i just bought i!And i want to do it by myself.
well, coz i am new with it, so can anyone tell me what should i becareful of?
and i know i have to remove the sesonator, is it hard?
i got everything, planning to install it tomorrow.
hope someone can give me some advices so i won't fvck up my car, heh..
well, if it's possible pls give me a website for " how to install it". thanks you all!!
Old Nov 24, 2003 | 03:05 PM
daywong's Avatar
Default Re: Aem Cold Air System Question (daywong)
o please, give me some advices~~Please
Old Nov 24, 2003 | 05:45 PM
2+2=5's Avatar
you'll need to take out the bumper, everything else is piece of cheese cake
Old Nov 24, 2003 | 06:09 PM
Legendaryyaj's Avatar
Default Re: Aem Cold Air System Question (2+2=5)
u dont need to take out the bumper....it jus makes it a bit easier but the screw to teh bottom resonator is a pain..it might take ya a while..its only accescible from the bottom of the car if the bumper is not taken off...thas about the hardest part.
Old Nov 24, 2003 | 10:37 PM
Kavehman's Avatar
what years ur accord ?
Old Nov 25, 2003 | 05:24 AM
daywong's Avatar
Default Re: Aem Cold Air System Question (Kavehman)
1994 ,
i searched, and someone said i got to jack up the right front part in order to remove the resonator. is the true?
Old Nov 25, 2003 | 06:17 AM
EX-JAY's Avatar
I just put a cold air intake on my 1997 Accord, pretty similar to ur car. You don't have to remove your bumper. Just remove the splash guard and your entire factory air system, including resonator. I will help greatly if you have access to a floor jack or something that can lift the car a little high. It makes it easier to see where the bolts are and what not.
If your car is equipped with a V-6, I have a link with step-by-step instructions and pics, let me know.
Old Nov 25, 2003 | 11:14 AM
Notaverage's Avatar
Default Re: Aem Cold Air System Question (EX-JAY)
I did my 95 accord about 2 months ago and it only took about an hour and a half. the only thing that confused me was where to put the foam filter cap and putting the vacuum cap was difficult. You just have to heat it up a little bit with a lighter. But the foam filter cap is for Vtec equipped vehicles only (well only necessary). Make sur eyou put the splashgaurd back to lessen the risk of ingeting water into the engine.
This link is to an install of a 1990 accord. NOt 100% the same but may help.
http://www.hondapitstop.com/ac....html
Dont worry with our generation there is no modifications needed. I was surprised how much i actually had to take out. If you dont know what your doing 100% with reconnecting adn rerouting the lines i suggest having someone take a look at it when your finished or have someone do it. At the most i figure it would cost around $60.00
well good luck
Kris
Old Nov 25, 2003 | 01:31 PM
daywong's Avatar
Default Re: Aem Cold Air System Question (Notaverage)
well, where's should the vacuum cap for??
pls tell me~~tys
Pilky
Sep 6, 2006 08:08 PM
standbackimapro
Nov 24, 2005 07:09 AM
SlammedCD7
Dec 8, 2003 09:18 AM
quik sol
Aug 26, 2003 01:07 AM
