Trailing arm question for Gsr to civic rear brake converison
Old Nov 24, 2003 | 01:43 PM
Jdm93civic's Avatar
Default Trailing arm question for Gsr to civic rear brake converison
ok let say i get a gsr trailing arm......does that mean that it will come with gsr lower control arms..........another question is right now i have GC's and KYB AGX's on the whole car....so the back shocks can still work with the gsr trailing arm...or no?
Old Nov 24, 2003 | 02:33 PM
2lua's Avatar
Default Re: Trailing arm question for Gsr to civic rear brake converison (Jdm93civic)
are you buy it as a complete swap? if yes then it should come with everythings and if no then it will not come with lca. yes your gc and kyb will still work.
Old Nov 24, 2003 | 02:56 PM
kommon_sense's Avatar
Default Re: Trailing arm question for Gsr to civic rear brake converison (2lua)
you change the trailing arms, not the control arms. So your shocks/springs will still work.
Old Nov 24, 2003 | 06:04 PM
Jdm93civic's Avatar
So i can use the stock civic lcr with the gsr trailing arm.....?
Old Nov 24, 2003 | 06:49 PM
2000blackgsr's Avatar
Default Re: (Jdm93civic)
All the brake swap stuff you will need to know
https://honda-tech.com/zerothread?id=152884
Old Nov 25, 2003 | 05:16 AM
Jdm93civic's Avatar
omg ..............you rule my fren!!!
noworldorder
Suspension & Brakes
Jul 15, 2009 03:11 AM
RabbittZ
Suspension & Brakes
10
Jul 5, 2005 11:32 AM
jcivic
Jun 23, 2003 07:00 PM
