Fuel injector question 235cc????? Vs 325cc
Old Nov 24, 2003 | 06:56 AM
nickwilmot's Avatar
Default Fuel injector question 235cc????? Vs 325cc
Hi,
I know that prelude Vtec uses a 325cc P&H injectors, but I don;t have them and I have a extra D16 Vtec IM from a swap, complete. I also will have to use the TB from the D16.
Just wondering if 235cc injectors could work temp. in a 94 Vtec prelude engine? Also if I also used the D16 Vtec TB would it work as well. This is only to test if I get any CEL's. and make sure everything is hooked up right. The motor will problably Idle for about 1 hour or so.
Thanks
Old Nov 24, 2003 | 07:03 AM
kb58's Avatar
Banned
Default Re: Fuel injector question 235cc????? Vs 325cc (nickwilmot)
For your test it should be fine as long as they are also P&H. Don't expect to be able to do much driving though. Just the size difference will limit you to 2/3 power.
Old Nov 24, 2003 | 07:24 AM
nickwilmot's Avatar
Default Re: Fuel injector question 235cc????? Vs 325cc (kb58)
the D16 injectors are not P&H but I'm going to be using the P28 ecu for now, I don't even plan on driving the car with the Temp setup. Just want to make sure evrything is ok.
Just turn it on for about 1 hr and then turn it off. Thats all. Problay another 1 month or so before it sees the road
Old Nov 24, 2003 | 08:18 AM
JDogg's Avatar
the ecu dosnt matter, you would have to rewire the injectors so as not to use the resistor box. i just saw that you have a civic, so no big deal
the dseries if not a vtec motor are 190 cc, the h22 injectors are 345cc if they are jdm 4th gen or 290 if they are usdm 5th gen. if you put the civic injectors in there crank up the fuel pressure, the p28 with civic injectors probably wont idle the motor
Old Nov 24, 2003 | 08:34 AM
nickwilmot's Avatar
Default Re: Fuel injector question 235cc????? Vs 325cc (JDogg)
The injectors are 235cc. The engine is going into a 93 EH, so wiring for the injectors is already correct.
Modified by nickwilmot at 7:32 PM 11/24/2003
Old Nov 24, 2003 | 09:44 AM
JDogg's Avatar
im assuming you are talking about d16vtec injectors, they are 240's i have seen them on a flow bench. the nonvtec d series are 190
Old Nov 24, 2003 | 10:34 AM
nickwilmot's Avatar
Yes they are the D16 Vtec injectors, like I mentioned above.
Old Nov 24, 2003 | 03:24 PM
fastludeh22's Avatar
i wouldnt do it. p28=lean, 240=lean p28+240cc=
if you want i have a set of 93 h22 injectors
killrroyale
Jul 24, 2014 06:53 AM
X arkangel x
Apr 17, 2003 12:00 PM
hanginlow
Apr 9, 2003 10:31 PM
ludelvr
Jun 13, 2002 05:40 AM
uneekcrx
Mar 26, 2002 06:11 PM
