tps problem???
my question is can the tps make the idle bog up and down in complete stop idle?
my situation with my gsr ek is that im throwing a CEL code 7 which is the tps i believe..im throwin other codes too like code 41 and code 23...i warm up my car for about a min or so and then drive...when i come to a stop the idles goes up and down between 1k and 2k...but after i drive around for 5 mins or so, it idles perfect at 700ish. so do u guys think its the tps? im checking it out wednesday but just want to know ur experiences.
also on a side note, for the knock sensor code 23, do i have to wire the knock sensor? i thought that i didnt have to when u swap it into an ek with the ex harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by photec3 »</TD></TR><TR><TD CLASS="quote">if you probe the middle wire of the tps with a multimeter is should read like .49volts. </TD></TR></TABLE>
thanks photec. i gotta check this as well. it's either gotta be tps or iacv, from the look of things.
streetsold6teeny8
Mar 24, 2012 06:46 PM
chinese acrobat
35
Nov 1, 2009 12:00 PM
