Spedometer Problem
Old Nov 23, 2003 | 06:57 PM
Puki
Guest
Posts: n/a
Default Spedometer Problem
I dropped my transmission to put in a new clutch and flywheel.
Put everything back together.
Now my Spedometer does not work. I have heard it is located under my intake manifold/throttle body and has 2 hoses connected to it.
What makes the unit function? What could be the most probable cause?
Thanks
Old Nov 23, 2003 | 07:15 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Spedometer Problem (Puki)
check the speedsensor on the tranny...its towards the fire wall on the back/top of the tranny next to the rear mount bracket.
Old Nov 23, 2003 | 08:25 PM
boostedbastard's Avatar
Default Re: Spedometer Problem (bruceleeroy)
What model car are you asking about? If it is a cable tranny then the hoses you are refering to are for speed sensative steering but do not have anything to do with the speedo working.
Old Nov 23, 2003 | 08:45 PM
SYD's Avatar
SYD
Default Re: Spedometer Problem (boostedbastard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedbastard &raquo;</TD></TR><TR><TD CLASS="quote">What model car are you asking about? If it is a cable tranny then the hoses you are refering to are for speed sensative steering but do not have anything to do with the speedo working .</TD></TR></TABLE>
thats what i was thinking also...
Old Nov 24, 2003 | 10:06 AM
T.J.'s Avatar
you need to plug in your VSS
Old Nov 24, 2003 | 11:48 AM
rig9896's Avatar
Default Re: Spedometer Problem (Skunk2whore)
Check the VSS (vehicle speed sensor) if it is plugged in and still isn't working it could be bad, they usually go around 100.000 miles.
Old Nov 28, 2003 | 02:58 PM
Puki
Guest
Posts: n/a
Default Re: Spedometer Problem (rig9896)
Oops didnt include type of car. 1993 H23 Lude.
The VSS is located under the intake manifold/throttle body, near the rear mounting bracket right?
I remember taking it off when I removed the rear mounting bracket.
What do you mean by plug in the VSS? Is it a hose/ wire?
Aesthetic Gains
Jun 19, 2008 12:31 AM
gRim06
Apr 19, 2007 10:29 AM
revlimitcrx
Apr 25, 2006 11:24 AM
beelzebub
Mar 20, 2006 08:51 PM
Roy2377
Nov 11, 2004 11:49 AM
