b20 max over bore
The most that I would ever sleeve a stock b20 block is to 85mm. Not 86mm I would never go 2mm over stock bore. But if you want to be safe and not risk anything I would just get it resleeved then slap in some 86mm slugs. just me thoughts
i've got a ton of b20's running 85's..no problems..but beware..regardless or bore size. b20's have WEAKER SLEEVES than the other b series. the sleeves were casted differently and they split after a while, especially with the increased compression people put in them and the increased rpm. if you can afford it...get a ls block with a cracked sleeve, and get ductile iron sleeves installed, then go 85mm. you will never blow those up. http://www.rsmachines.com . 310-328-5514
xxjonxx4
15
Jan 24, 2013 04:22 PM
