What offset on rims??
Old Nov 23, 2003 | 03:18 PM
STEALTHMODECOUPE's Avatar
Default What offset on rims??
on some 16X7 rims what offsets can you get by with on an EK without it looking to far in or sticking to far out?? TIA
adaM
Old Nov 23, 2003 | 05:46 PM
zer0.'s Avatar
i suggest a 45 offset.
Old Nov 23, 2003 | 06:03 PM
Default Re: (zer0_2_6ixty)
what about 34?? if not whats wrong with 34
Old Nov 23, 2003 | 06:04 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (STEALTHMODECOUPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEALTHMODECOUPE &raquo;</TD></TR><TR><TD CLASS="quote">what about 34?? if not whats wrong with 34</TD></TR></TABLE>
I'm probably going to run a 28-32 offset with 14x6 inch wheels...which is RIGHT at the fender.
With a 7 inch wide and a 34, you might start to stick out
Old Nov 24, 2003 | 07:21 AM
Default Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
With a 7 inch wide and a 34, you might start to stick out</TD></TR></TABLE>
DOH! thanks for the info though
adaM
Old Nov 24, 2003 | 07:50 AM
Philip's Avatar
I have 16x7 +40 mm offset, check my sig for more pics
Old Nov 24, 2003 | 09:28 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: What offset on rims?? (STEALTHMODECOUPE)
7" +38 is just about the limit you can go. also, depends on what tires you run. i use 225 width hoosiers, which are a lot wider than any street tire.
i run a 8.5" wheel with +19mm offset, but some people have referred to me as "crazy". go figure.
Old Nov 24, 2003 | 09:31 AM
HUBB's Avatar
Default Re: What offset on rims?? (rodney)
38
Old Nov 24, 2003 | 09:43 AM
so a 34 wouldnt work on a 6th gen civic??
adaM
Old Nov 24, 2003 | 10:26 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">7" +38 is just about the limit you can go. also, depends on what tires you run. i use 225 width hoosiers, which are a lot wider than any street tire.
i run a 8.5" wheel with +19mm offset, but some people have referred to me as "crazy". go figure. </TD></TR></TABLE>
13x8.5s with 225 HooHoos - best wheel/tire combo ever
albertleee
Nov 28, 2007 09:12 PM
accord03coupe
Honda S2000
14
Sep 23, 2007 05:45 PM
nonvtec92
Aug 5, 2007 12:02 AM
mrlegoman
Jul 6, 2006 08:41 AM
t o m
Honda S2000
37
Mar 18, 2005 06:35 PM
