Car Stalls out when i turn on AC
Old Nov 23, 2003 | 02:58 PM
BoM's Avatar
BoM
Default Car Stalls out when i turn on AC
the normal air cool or heat works fine. but i need a/c in order to defog my windows better. when i push the a/c on the car just stalls and dies out. only when the ac is on.
do i need to recharge it or something? or electrical problem? where should i start looking?
i've already checked the fuses.
Old Nov 23, 2003 | 04:46 PM
Kendall's Avatar
Default Re: Car Stalls out when i turn on AC (BoM)
I don't know what the problem is but I have to recommend not turning on the AC.
Old Nov 23, 2003 | 05:58 PM
Chiovnidca's Avatar
Is the compressor locked up?
Old Nov 23, 2003 | 08:32 PM
AMG's Avatar
AMG
Default Re: Car Stalls out when i turn on AC (Chiovnidca)
Obviously, not enough power. I'd say make sure you dont ned to recharge the battery
Old Nov 23, 2003 | 09:55 PM
BoM's Avatar
BoM
i think it spins freely because its turning with the belt.
would having no freon cause this?
Old Nov 23, 2003 | 10:18 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Is the compressor locked up?</TD></TR></TABLE>
A locked or seized AC compressor will not stall a vehicle rather it will break the belt or shred it.
Old Nov 23, 2003 | 10:23 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoM &raquo;</TD></TR><TR><TD CLASS="quote">the normal air cool or heat works fine. but i need a/c in order to defog my windows better. when i push the a/c on the car just stalls and dies out. only when the ac is on.
i've already checked the fuses.</TD></TR></TABLE>
It sound to me that you have an electrical problem. You stated that the compressor wheel spin freely. So, does your raises when you turn on the AC? or does it just idles low and stalls?
Its either that the PCM is not getting the singal that the AC turn on or the PCM is responding. Anyways, the PCM is suppose to raise the idle when the AC is turn on.
Old Nov 24, 2003 | 09:48 AM
BoM's Avatar
BoM
Default Re: Car Stalls out when i turn on AC (HONDADNA)
it idles fine with the air on. but it just stalls out as soon as i turn on the a/c.
whats PCM stand for? where do i check for continiuty ?
soo the pcm is suppose to keep the engine running enough to idle and run the a/c compressor load?
Old Nov 24, 2003 | 02:15 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">
A locked or seized AC compressor will not stall a vehicle rather it will break the belt or shred it. </TD></TR></TABLE>
Yes they can if it's just idleing when you turn it on.
Old Nov 24, 2003 | 07:17 PM
BoM's Avatar
BoM
it idles fine, when im driving and hit the a/c it'll stall even trying to keep the rpms up. the engine just dies.
Old Nov 24, 2003 | 09:00 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoM &raquo;</TD></TR><TR><TD CLASS="quote">it idles fine, when im driving and hit the a/c it'll stall even trying to keep the rpms up. the engine just dies. </TD></TR></TABLE>
Well one test you can do to see if your compressor is seize. You can activate the compressor clutch and see if your can turn it by hand.
Old Nov 24, 2003 | 10:53 PM
Rtype16's Avatar
Do you have some sort of aftermarket computer on your car.
Old Nov 25, 2003 | 08:02 AM
mmuller's Avatar
Mad Scientist
Default Re: Car Stalls out when i turn on AC (Rtype16)
check your eld
Old Nov 25, 2003 | 08:06 AM
Crazydave's Avatar
Sounds like you have a problem with your A/C SYSTEM!
I had the same problem..
the AC pump would making way too much pressure..
things to look for..
clogged lines, bad pump, clogged condensor,
or take the belt off, and keep the AC off until you have it looked at by a qualified AC technician.
You have to be carefull with AC due to laws.. and
danger to yourself..
AC systems make a lot pressure....especially when they are malfunctioning like yours.. I am willing to be that the "Hi Side" is making in excess of 600psi and I bet the low side is making way too much pressure too
Old Nov 25, 2003 | 09:02 AM
LODOSS's Avatar
if you got aftermarket cams and the car is not tuned it'll die on you cause your car is not able to keep its rpm stable to supply the power needed for the AC/belt/compressor etc etc
Old Nov 25, 2003 | 12:49 PM
BoM's Avatar
BoM
Default Re: Car Stalls out when i turn on AC (LODOSS)
soo im looking at the whole a/c system. can i cross off the electrical as a problem?
i will check if its the pulley, the compressor, or the over pressured system?
crazyguy
Jul 25, 2007 02:27 PM
sPaRk'iT
Jun 28, 2007 06:23 PM
tub_sephiroth
Jun 27, 2005 11:13 AM
jlamaster
Oct 1, 2004 07:12 PM
metal-x
Jul 22, 2003 10:47 AM
