Key Interlock Fix - Instead of leaving gear selector switch under console-
Old Nov 23, 2003 | 08:33 AM
_jester_'s Avatar
Default Key Interlock Fix - Instead of leaving gear selector switch under console-
For thos who have swapped Auto - Manual I have a contribution-
OK, i sat down with my manual and my toob ( )and came up with a solution to leaving the gear selector under the center console.
You make continuity betweens pins 1 & 12 and also between pins 10-11.
This is a diagram of the pinout (plug for shift selector)
This is mine actually done- No problems remove key....WOOHOO!
I know i didn't want to leave my gear selector under my console- and i figured there are others who wouldn't also!
Then for the clutch pedal, make sure the clutch safety sensor is grounded.....Voila! This all should work, i can't start my car yet so i can't test it out. But soon.....very SOON!
Modified by XratedSi at 12:45 PM 11/23/2003
Old Nov 23, 2003 | 08:46 AM
_jester_'s Avatar
Default Re: Key Interlock Fix - Instead of leaving gear selector switch under console- (XratedSi)
PIcs now included
Old Nov 23, 2003 | 09:15 AM
mad_96civic's Avatar
could you plz explain to me whats going on? you need to what?
your auto tranny has (had) some safty switch?
Old Nov 23, 2003 | 01:16 PM
_jester_'s Avatar
Default Re: (mad_96civic)
If you are doing an auto to manual swap -you'd understand. It so after you do the swap you can take your key out of the ignition-
Old Dec 31, 2005 | 01:25 PM
cbondura's Avatar
Default Re: Key Interlock Fix - Instead of leaving gear selector switch under console- (_jester_)
I am trying to complete my auto to tranny swap and cannot crank the car. Your images are no longer available, so I am having a hard time determinig which pins you are talking about. I assume you are refering to the large connector which plugged into the auto shifter.
Do you posting the photos again or some type of diagram?
Adam McCormick
Transmission & Drivetrain
Nov 12, 2017 05:04 PM
Ryan Doyle
Apr 14, 2013 10:22 AM
coolusername
Honda Civic (2001 - 2005)
56
Sep 6, 2011 11:25 AM
cinaibur
Nov 10, 2006 04:21 AM
91civic4d
Oct 11, 2002 12:29 PM
