Power Windows
Ok....so now my driver side power window is faulting. all fuese are ok, and the regulator was already replaces a while ago. Most likely a short in the line....motor isnt getting any power what soever. the window was able to go down fine, but when i got home, i wasnt engaging at all. 94 EX....any suggestions......id rather not have to take apart the door panel and manually pull the window up, but if thats what it takes.....thanks
Yea I was just gonna say, check the switch. I just had an LS at work last week with both rear windows not working all the time, or sometimes just in one direction. All it was was the master switch gone bad... simple fix. If you have an electrical manual with the pinouts of the switch you can test the continuity of the switch(s) for each position and see if they're making contact or not.
ok.....so....im anything but an electrician.....so i have no clue what that means.....i do have a haynes manual, if that helps.......so what should i do...i dont wanna spend the money to take it anywhere
honda_civic1993
Nov 25, 2012 10:46 AM
