How do i wire in gauges.
Hey guys, I just picked up some little gauges for my car that read volts, oil pressure, water temp, but i do not know where to plice each wire for...can someone show me a diagram or pics on where to wire them at? Thanks in advance.
well the red and black is power and ground ( which you probably already know ) just hook the red up to any 12v power like headlight or your dimmer for your cluster and groud look for a bolt to ground too. the rest i dont know im no help
voltmeter is easy
you got positive and negitive that you want going to well duh...
but if you want it to pulse to your music you could hook it up behind your deck so when your deck takes a lot of power your guage reads it
and there should be a bulb on each of your guages, if you want to hook them up with your night lights youll need a relay to tell your aftermarket guages to turn on,
and if you want a dimmer youll need a vairable resistane dimmer switch for it
burgoyne17
Oct 7, 2012 11:48 AM
Blazin Civic
Jun 21, 2004 08:30 PM
