oil pressure down 8psi after rebuild??????
Old Nov 23, 2003 | 06:55 AM
99B16Si's Avatar
Default oil pressure down 8psi after rebuild??????
well the rings in my car were shot so i decided to rebuild the bottom end with some fresh new rings. the old ones were getting bad blow by and my car started to smoke. after i finishes i noticec that my oil pressure gauge isnt acted the same. normal once the car is fully warmed up the oil pressure would climb to 80psi the kinda kick back to about 72psi at around 3500rpm(give or take a few RPM).....
now, with the car fully warmed up the oil pressure will only climb to about 72psi then fall back to about 63psi but still at the saem RPM(around 3500). its also about 3-4psi lower at idle
all i did was pull the head and oil pan. i didnt touch any of my oil lines or anything like that, just undid the lsvtec line from the head.....
i only have 3 ideas....
1. the excess blowby i was getting was creating more pressure thru the oil passages
2. my oil filter is backed up
3. my oil pick up tube gasket is leaking
any ideas??????
Old Nov 23, 2003 | 08:58 AM
VaporTrail's Avatar
New User
Default Re: oil pressure down 8psi after rebuild?????? (99B16Si)
did you put in new bearings?
Old Nov 23, 2003 | 09:03 AM
99B16Si's Avatar
the bearings only have like 10k miles on them and still looked practically brand new excpet one of them that looked alittle worn but nothing to serious. i decided to replace it while i had it apart just for the hell of it. so basically i have 2 new bearings in the motor. why would that matter?
Old Nov 23, 2003 | 09:12 AM
HYBRID_H@TCH's Avatar
Default Re: (99B16Si)
if your bearings are out of clearance it will cause low oil pressure.
Old Nov 23, 2003 | 09:14 AM
99B16Si's Avatar
theyre not out of spec
Modified by 99B16Si at 6:52 PM 11/23/2003
hatchedeg
12
Feb 2, 2008 10:55 AM
Fo-Do Fanatic
14
Jan 15, 2007 06:33 PM
boosted_zc
May 31, 2004 09:54 AM
vtec.dc2
Mar 9, 2004 04:41 AM
Snafu-Si
Mar 24, 2003 10:47 PM
