ELECTRONIC BOOST GAUGE INSTALL QUESTION
Old Nov 23, 2003 | 06:04 AM
djnikko's Avatar
Default ELECTRONIC BOOST GAUGE INSTALL QUESTION
hi guys
I got an electronic boost gauge with four wires coming out the back. One red (+) one balck (-) one yellow wire for dimming light and the other wire (orange) goes to some kind of sending unit with two male spade connectors pedruding from it. I am not sure what boht of the spade connectors are for im guessing one is where the orange wire goes. The two spade terminals are marked s and -
do the electronic gauges use vaccuum tubing? I thouoght this was from mechanical
any help would be great
Old Nov 23, 2003 | 08:08 AM
djnikko's Avatar
Default Re: ELECTRONIC BOOST GAUGE INSTALL QUESTION (djnikko)
basically in a nutshell im wanting to know if an electronic boost gauge uses vaccuum piping? as i havent had it provided in the kit.
can someone maybe explain the difference between a mechanical gauge and electronic gauge? the gauge is a RaceX
Old Nov 23, 2003 | 09:10 AM
DA-MAX's Avatar
if its electrical did they provide a sensor of any type? I would assume they would have provided a boost/vacuum sensor of some sort that would register readings back to the gauge from whereever your source is (vac manifold, etc).
a mechanical gauge would just run capillary tubing from the source back to the gauge
Old Nov 23, 2003 | 03:23 PM
Foozball26's Avatar
Default Re: (DA-MAX)
what kind of guage is it?
did you read the instructions?
yes, electrical gauges use a sending unit, which a vacuum source it plugged into, then wires go from the sending unit to the guage.
Old Nov 28, 2003 | 12:35 AM
djnikko's Avatar
Default Re: (Foozball26)
its a raceX gauge ... think i got it sorted now thou. thanks
skuded
Apr 21, 2011 04:38 PM
civicguy1984
Nov 19, 2004 06:05 AM
streetlvlhatch
Feb 13, 2004 08:20 PM
