Turbo si spark plugs?
Old Nov 22, 2003 | 09:35 PM
BLACKLUDE97's Avatar
Default Turbo si spark plugs?
what kind of spark plugs and wires should i get . i have a 00 civic si turbo. so whats the best kind to get and whats the model number or series of the spark plugs and wires.
Old Nov 22, 2003 | 10:51 PM
turbo Si's Avatar
Default Re: Turbo si spark plugs? (BLACKLUDE97)
I would say to stick with the stock wires. Other than that go with the NGK blues. If you want I will sell you mine for $30.00 bucks. They are about a year old.
Also do a search. That's how I found out the same info!
Old Nov 22, 2003 | 11:06 PM
Deluzional's Avatar
Default Re: Turbo si spark plugs? (turbo Si)
the plugs I am running are 1 step colder BCPR7ES and i just stuck with my stock wires
Old Nov 23, 2003 | 08:13 AM
anyone else??
Old Nov 23, 2003 | 08:17 AM
PrecisionH23a's Avatar
Default Re: Turbo si spark plugs? (Deluzional)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">the plugs I am running are 1 step colder BCPR7ES and i just stuck with my stock wires</TD></TR></TABLE>
Part number 3330, those are actually 2 steps colder then stock though. Those are the plugs you want to run, period. Gap them to .030-.032 and you will be fine.
Old Nov 23, 2003 | 08:34 AM
99B16Si's Avatar
good cheap plugs would be NGK BKR7E-11 gapped to about .028-.032 depending on the application/boost levels
im am running the equivalent plugs in the NGK iridium series. they work awesome but i dont know the part number off the top of my head. they also last about 5 times longer but are about $25-30 a set
Old Nov 23, 2003 | 11:09 AM
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">good cheap plugs would be NGK BKR7E-11 gapped to about .028-.032 depending on the application/boost levels
im am running the equivalent plugs in the NGK iridium series. they work awesome but i dont know the part number off the top of my head. they also last about 5 times longer but are about $25-30 a set</TD></TR></TABLE>
NGK iridium's are a waste of money.
Quick note: When getting a plug do not get the '-11' because they will come gapped to a .044. Instead get them without the '-11.' The plug will come with around a .032-.035 gap so the tip endures less stress when re-gapping. Also, I used to be a fan of the bkr7e until I compared them to the bcp7es's. The bkr7e's electrode actually extends further into the combustion chamber which introduces it to hotter temperatures that can lead to pre-ignition and/or detonation. The bcp's electrode is a lot shorter and safer to run in boosted motors. The price of the 3330's (bcp7es) vs the bkr7es-11's are the same if not maybe 10 or 20 cents in difference.
Old Nov 23, 2003 | 11:30 AM
Deluzional's Avatar
Default Re: Turbo si spark plugs? (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">
Part number 3330, those are actually 2 steps colder then stock though. Those are the plugs you want to run, period. Gap them to .030-.032 and you will be fine.</TD></TR></TABLE>
Oh really, i was always under the impression that i was running 1 step colder. BTW I have an extra set of these lying around if anyone needs um...But it is bcpr7es-11
Old Nov 23, 2003 | 10:15 PM
i'll take them. pm me.
Old Nov 23, 2003 | 11:09 PM
MaxSterling's Avatar
Default Re: (BLACKLUDE97)
BKR7E is already gapped to 0.03"
Old Nov 24, 2003 | 06:08 AM
99B16Si's Avatar
Default Re: (MaxSterling)
the ones i get arent. theyre always at .044 when i get them
Old Nov 24, 2003 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">the ones i get arent. theyre always at .044 when i get them</TD></TR></TABLE>
thats because you run the '-11's
Old Nov 24, 2003 | 06:09 PM
double0Si's Avatar
Default Re: (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote"> Also, I used to be a fan of the bkr7e until I compared them to the bcp7es's. The bkr7e's electrode actually extends further into the combustion chamber which introduces it to hotter temperatures... </TD></TR></TABLE>
Good to know...
digitalvice
17
Mar 25, 2013 03:14 PM
meagainsttheworld
10
Mar 27, 2007 08:37 PM
AllMotor12s
May 19, 2004 02:30 PM
jdmjeff
12
Nov 20, 2003 01:26 AM
hybrider
Apr 25, 2002 06:44 AM
