speedo sensor?
Old Nov 22, 2003 | 07:49 PM
vteczone's Avatar
Default speedo sensor?
will the speedo sensor at the gearbox effects the Vtec engagement if it is not connected?what effect it produce if not connected?
Old Nov 22, 2003 | 08:10 PM
curt801's Avatar
vtec won't engage unless the speedo is connected. i have a b17 and i need to know how to fix this too. if any one has a pic or diagram it would help me a lot
Old Nov 22, 2003 | 08:18 PM
vteczone's Avatar
Default Re: (b1788crx)
what if i use a standalone engine management,will the vtec still wont engage if not connected?
Old Nov 22, 2003 | 08:23 PM
curt801's Avatar
i am not sure i know my vtec would work when i used a muguen chipped ecu but not with any other stock ecu.sorry that i can't help i just don't know
Old Nov 22, 2003 | 11:38 PM
dohcnotec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b1788crx &raquo;</TD></TR><TR><TD CLASS="quote">i am not sure i know my vtec would work when i used a muguen chipped ecu but not with any other stock ecu.sorry that i can't help i just don't know</TD></TR></TABLE>
Aftermarket chips such as "Mugen, Spoon, Skunk," etc usually cut the sensor checking routines (O2, VSS, etc) out of their program, and sense most aftermarket programs (including the real Skunk) are knockoffs of old mugen programs, they are virtually the same.
If you are using a stock Honda ECU or Hondata ecu, you need to have your VSS/Speed sensor hooked up. Vtec won't engage unless the ecu sees that ur going over 6mph. What's wrong with your speedo neway?
Old Nov 23, 2003 | 11:27 PM
vteczone's Avatar
Default Re: (dohcnotec)
im in the process of putting the engine back in the bay and notice that the cable has broken or probably lose inside.im using haltech engin management so wondering if that effects my vtec engagement.i have not started up nor check whats wrong with cable yet.
fyah2k5
Aug 25, 2014 11:19 AM
P12 EG6
13
Oct 17, 2007 03:06 PM
jedsus
11
Jun 20, 2006 02:04 PM
drvfast
Sep 22, 2004 05:15 PM
jdmwidebody094
11
Sep 4, 2003 03:04 AM
