mini me problem
Old Nov 22, 2003 | 09:59 AM
SpoolinEK's Avatar
Default mini me problem
i want to know why at high rpm my d15vtec blows smoke around 5-6rpm??? could it be the headgasket going out? anyone?
Old Nov 22, 2003 | 10:35 AM
chad's Avatar
Moderator
Default Re: mini me problem (EG Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG Civic &raquo;</TD></TR><TR><TD CLASS="quote">i want to know why at high rpm my d15vtec blows smoke around 5-6rpm??? could it be the headgasket going out? anyone?</TD></TR></TABLE>
rings on your pistons are bad, or you valve seals are bad.....headgasket would mostlikely blow all the time not just at specific spots in rpm band
Old Nov 22, 2003 | 10:43 AM
Andres-eh2's Avatar
What color smoke?
Old Nov 22, 2003 | 10:52 AM
95cxhatch's Avatar
Default Re: (EGEESIX)
one of friends had the problem and someone told that his rings were stuck to the piston due to carbon buildup, you could try getting some sort of cleaner of some sort.
Old Nov 22, 2003 | 01:41 PM
SpoolinEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGEESIX &raquo;</TD></TR><TR><TD CLASS="quote">What color smoke?</TD></TR></TABLE>
black smoke
Old Nov 22, 2003 | 01:46 PM
Del_Sol_s's Avatar
isnt black smoke too much fuel which is that your running rich.
Old Nov 22, 2003 | 02:13 PM
SpoolinEK's Avatar
Default Re: (jdmvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvic &raquo;</TD></TR><TR><TD CLASS="quote">isnt black smoke too much fuel which is that your running rich.</TD></TR></TABLE> would that mean my o2 sensor is dead...if so..my checklight is not showing up.
Old Nov 22, 2003 | 02:44 PM
chad's Avatar
Moderator
Default Re: (EG Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG Civic &raquo;</TD></TR><TR><TD CLASS="quote"> would that mean my o2 sensor is dead...if so..my checklight is not showing up.</TD></TR></TABLE>
doesn't always show up.....could be it is not reading correctly at that rpm....if you still have your one wire o2 then that maybe a cause
Old Nov 22, 2003 | 04:10 PM
FMIDRC Racer's Avatar
i just did a mini me and i was blowing out black smoke. i put a oil catch can between the valve cover and the intake and it doesn't smoke anymore and there is allot of oil in the can. i've only had the can on there for 4 days now. the can i sed is a 3/8 inline glass fuel filter with no filter element inside. it works great so far. and yes, i know it was black smoke and not blue.
Old Nov 22, 2003 | 05:13 PM
4whldft's Avatar
your vtec is set a little rich that is all.
tony sm 140
Old Dec 5, 2003 | 01:35 PM
Default Re: (4whldft)
yeah mine started to smoke again as well. oh well i'll just deal with it. the z6 bottem goes in soon....weeee!
Old Dec 7, 2003 | 02:40 PM
dogfood's Avatar
the piston rings are probably the problem. If it happens at startup its the valve guide seals, but at a certain rpm its the rings.
streetcartuner
Sep 14, 2006 09:21 AM
escape2me
Jun 29, 2005 11:24 AM
Spec R
Apr 22, 2005 09:16 AM
I got a honda
Mar 14, 2005 07:22 PM
