rag kit and theDeltagate Qs
Guest
Posts: n/a
I just installed my drag kit and i guess either the wg or boost controller is acting up. well i know its the boost controller, pos turboXS. anyways i saw my car boost like 10lbs and am scrud shitless. i need to know how to fix w/o buying a new boost controller.
can i just remove the top fitting on the deltagate and have the fitting running from the side of the wg to the turbo? also, the spring part, its all the way in. is that right or should i be out?
yes, i did research, but the info is not clear. can some1 enlighten me?
what i no:
boost controller is fwaked
i can run from the fitting on the side of the wg to the turbo
i should make the spring part all the way up, if i dont want it to boost a lot
questioned:
do i need to plug up the top fitting?
and is it safe if i do this ratehr then a boost controller?
thankx in advance
what i no:
questioned:
thankx in advance
