clutch acting up, is it dieing?
Old Nov 21, 2003 | 08:42 PM
oMek's Avatar
Default clutch acting up, is it dieing?
when i run my car hard or for a long time the clutch pedel gets really soft like 1/2 down and just falls. it did it alot when i got the car so i bleed the fluid and used ate super blue. that stoped it for a while but tonight it started doing it again. someone said that my clutch is on its way out is this true?
it always grabs and i never feel it slip.
Old Nov 21, 2003 | 08:46 PM
94B18B1Teg's Avatar
Default Re: clutch acting up, is it dieing? (oMekoneDC2)
when I first got my 94 LS, the clutch was just about gone, the pedal was REALLY soft, like, it felt like nothing was there, it was NOT slipping though. like I could hit 4th and you could feel it grab, but with hydraulic clutches it sucks cause they readjust themselves so you could have clutch one time, then the next day it could be gone, take the soft pedal as a warning. Go out there and get something nice, if you got a friend that works at a place that can get clutches that helps. Mine was close to $500 and I got it discounted at $270. I would either get someone to look at it, or get another man. don't risk it....I got a video of a type R racing a mustang, drops into 3rd, goes to hit 4th, and it was gone. He was left on the side of the highway, you don't want that to happen.
Old Nov 21, 2003 | 08:53 PM
NeoGSR's Avatar
ever replaced your clutch master cylinder? if not, look down where your clutch pedal connects inside the car under the dash....is there fluid leaking down? if so, replace your clutch MC...might be the culprit
Old Nov 21, 2003 | 09:02 PM
integraL's Avatar
Default Re: clutch acting up, is it dieing? (NeoGSR)
so the main sign of your clutch going out is the soft pedaL?
Old Nov 21, 2003 | 09:33 PM
artifex's Avatar
say it
Default Re: clutch acting up, is it dieing? (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoGSR &raquo;</TD></TR><TR><TD CLASS="quote">ever replaced your clutch master cylinder? if not, look down where your clutch pedal connects inside the car under the dash....is there fluid leaking down? if so, replace your clutch MC...might be the culprit
_______
check the slave cylinder area on your engine for fluid leaking as well.. mine would only leak when it was hot, and the clutch would go soft, but pressure would come back once it cooled off for a bit.
Old Nov 21, 2003 | 09:59 PM
oMek's Avatar
Default Re: clutch acting up, is it dieing? (artifex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artifex &raquo;</TD></TR><TR><TD CLASS="quote">
thats right on front of the trani right? right where you bleed it from?
Old Nov 21, 2003 | 11:56 PM
oMek's Avatar
i just checked where the pedel is and there is grese on the top of it but no fluid. the fluid level never goes down. i also checked where you bleed it and there was no leakage there. next time it does it im gona check there right away see if its leaking.
should i try and bleed it agian?
vi3tromanc3r
Mar 8, 2007 09:02 AM
Built B18ABorC
Aug 28, 2004 02:02 PM
2ksi
Aug 12, 2003 04:45 PM
Steve
Jul 23, 2001 01:42 PM
