Need Help ASAP...Axel Removal...97 Honda Civic LX
Old Nov 21, 2003 | 07:08 PM
PDXHatchback's Avatar
Default Need Help ASAP...Axel Removal...97 Honda Civic LX
I am puting in another motor in my Civic, (stock LX motor) got all the wiring out of the way but now I need to get the axels out, and they are getting stuck inside the hub. How do i slip them out????? Second is the linkage...I got one of them unbolted but cannot figure out how to unbolt the otherone. Can someone help me out ASAP.
Thanks!!!
Old Nov 21, 2003 | 07:30 PM
Default Re: Need Help ASAP...Axel Removal...97 Honda Civic LX (PDXHatchback)
Come on, I need to finish this tonight!!!
Old Nov 21, 2003 | 07:38 PM
C uR eX's Avatar
have you taken out the 32mm axles nut?
if not then usually the but have been dented in on the edge so it wouldn't move..all you have to do is get a flat head screw driver and tap it back into a circular shape and loosen the nut..ther is a trick i use but sticking a screw driver into the rotor vent and spin it til it hit the caliper (depending on which side axles you taking out) and then use a torque ratchet and loosen the nut...
hope this help..
Old Nov 21, 2003 | 07:44 PM
C uR eX's Avatar
oh also you did taken out all the nuts and bolts that hold up the front LCA/fork/shock/etc..?
Old Nov 21, 2003 | 08:02 PM
Default Re: Need Help ASAP...Axel Removal...97 Honda Civic LX (C uR eX)
Got the nut out, tried to tap it out of the hub and it didnt work, how do I slip them out of the hub????
Old Nov 21, 2003 | 08:06 PM
hondafied's Avatar
axles ge rusted pretty bad in the splines. use a hammer but dont hit the crap out of it or you will not be able to thread the nut back on. linkage? if you mean shift linkage one of the bars unbolts and the other comes out with the tranny. if you mean another linkage please specify.
Old Nov 21, 2003 | 08:11 PM
C uR eX's Avatar
well in that case then spray some WD40 or rust penetrate can to the spline/hub and use a sledge type hammer and tap it out..and like the other guy mention becareful not to damage the head of it or else you can't thread the nut back in...
as for the linkage, if you're refering to the shift linkage...there is a lil pin that lock into the the linkage and the tranny. use a 10mm bolt or something similar in size to the pin and tap it out by using a hammer..
Old Nov 21, 2003 | 10:23 PM
sshaikh01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PDXHatchback &raquo;</TD></TR><TR><TD CLASS="quote">Got the nut out, tried to tap it out of the hub and it didnt work, how do I slip them out of the hub????</TD></TR></TABLE>
Get the lower control arm lose by getting the castle nut, than pull on the rotor, it while lightly hammering the axle, if not comming out, that should do the trick. If not post up more probs. hurry up
Old Nov 21, 2003 | 10:30 PM
ace1875's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C uR eX &raquo;</TD></TR><TR><TD CLASS="quote">use a sledge type hammer and tap it out..and like the other guy mention becareful not to damage the head of it or else you can't thread the nut back in...</TD></TR></TABLE>
DONOT USE A SLEDGE HAMMER. you will damage the transmission!
If you are droping the motor out from under the car just remove it with the hub then it will come off the tranny and use what you like
Old Nov 22, 2003 | 07:37 AM
C uR eX's Avatar
Default Re: Need Help ASAP...Axel Removal...97 Honda Civic LX (ace1875)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace1875 &raquo;</TD></TR><TR><TD CLASS="quote">
If you are droping the motor out from under the car just remove it with the hub then it will come off the tranny and use what you like</TD></TR></TABLE>
it not a sledge hammer...i'm refering to a smaller hammer but look just like a sledge hammer because using that will give you more pounding presure..and i mean TAP not swang that **** out of it...and why you want the guy to take the motor out with the whole susnpesion? that the harder way, assuming he has a cherry picker and all he has to do is take one axle out..do what the other guy about mention and take out the castle nut for the LCA and lift the hub out from the LCA and try to pull back on the axle while pulling the whole hub toward you..
redsidriver
Mar 24, 2009 08:09 AM
obrienjoe_05
Sep 2, 2008 07:59 PM
RoB316
Sep 21, 2006 06:40 PM
zach1288
Nov 19, 2005 10:39 PM
DragII
Nov 7, 2001 04:42 PM
