Need Help with non starting car
Old Nov 21, 2003 | 04:43 PM
MaukaRunner's Avatar
Default Need Help with non starting car
Hey guys, newb here. I have a problem and found this site and the members seem pretty knowledgable.
Here is my problem:
I have a 92 Civic DX, Hatch. All Stock. I thought I had the classic Main Relay problem so I went out and bought a new one. Still the car will not start. When I turn the ignition switch to on I don't hear the fuel pump. I did the jumper on the main relay and the fuel pump turns on when the ignition is on. I checked all of the fuses and they seem fine. Does any one have an idea what is going on. Thanks
Old Nov 21, 2003 | 04:45 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Sounds like it could be the ignition switch, not to hard to replace.
Old Nov 21, 2003 | 04:57 PM
Default Re: (1 point 6)
Thanks for the repsonse. Forgot to add this part:
The car cranks but there is no fuel pump activation.
Could the ignition switch still be causing this?? Is there any way of testing the system without the switch?
Thanks!
Old Nov 21, 2003 | 05:27 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (MaukaRunner)
The ignition switch controls a whole lot of vital stuff. I dunno if I can say 100% that's your problem, but if you have to change fuel pumps, upgrade to a Walboro 255 lph because it takes appx. one month on this site before you'll want a swap .
Old Nov 21, 2003 | 05:35 PM
Jimmy's Avatar
Global Moderator
Default Re: (Archidictus)
I'd say ignition switch.
BTW: how much do those go for now.
Old Nov 29, 2003 | 04:40 PM
Default Re: (SK101)
Thanks for the kool reception to the forums. I tested the all of the continuity points on the ignition switch and they all are good. I have a feeling it is the ecu. Is there something I can plug the ecu into to test it? If the ecu is bad what others are interchangable?
Sorry for all the questions but I kinda want the car running good before any swaps. Yeah this site is getting me swap itchy. Thanks again. One more question, what's the going rate for a ecu???
Old Nov 29, 2003 | 04:46 PM
aw1234dude's Avatar
I dont think the ECU will just go out on you for no reason. Did you do anything to the car or put anything into the car before this all happened, or did this just happen out of the blue. Make sure you double check all the fuses because once i fried the big ignition switch fuse and didnt catch it even after a couple visual checks.
Old Nov 29, 2003 | 05:05 PM
Default Re: (aw1234dude)
I checked all of the fuses. Since I had the meter out I checked continuty on all the fuses including underhood ones.
I noticed the passenger side carpet was soaked with water after a big rain and the carpet over the ecu was pretty damp.
The only indication of something was going bad was the common symptoms of a bad main relay but it was starting once in a while. I had a crack on one of the solder points but when I resoldered it the car would not start at all. It would crank but there was no fuel pump 2 second primer or anything. I did the jumper at the main relay connector and the fuel pump would work when the ignition switch was on. I even tried to jump the fuel pump with the main relay connected and the car would not start.
I am stumped .... anyone ??????
Modified by MaukaRunner at 2:22 AM 11/30/2003
Old Dec 9, 2003 | 05:52 PM
It was the ecu. I swapped it and it runs.
Old Dec 9, 2003 | 06:09 PM
2lua's Avatar
did you remove the battery before you resolder the joint? if you didnt than that is your problem right thurrr. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaukaRunner &raquo;</TD></TR><TR><TD CLASS="quote">I checked all of the fuses. Since I had the meter out I checked continuty on all the fuses including underhood ones.
Modified by MaukaRunner at 2:22 AM 11/30/2003</TD></TR></TABLE>
andyvaj
Aug 15, 2012 09:44 AM
melloman
Feb 14, 2012 03:41 PM
acidburn2k2
Dec 10, 2009 06:25 AM
RDAYA0
Jun 12, 2008 01:13 PM
squirrels
Jul 20, 2005 12:37 PM
