ZEX cam or new sc PULLEY
ok- here is the current mods
d16y8
jackson racing supercharger currently at 6lb
intake
header
test pipe
cat-back
fuel pump
safc
my question is, would it be better, as far as reliabilty, overall hp gains, and everything else considerd to buy the ZEX street/strip cam and springs or a 9lb pulley? Both would be dynoed and tuned using the safc after the install.
Modified by JICEK9 at 10:10 AM 11/21/2003
d16y8
intake
header
test pipe
cat-back
fuel pump
safc
the reason people havent responded is because they probably have no idea.... im sure both would make pretty decent power gains but i would personally go with a bigger pulley to start with. with more boost you will make more power accross the whole powerband where as with a cam you can only tune for low end torque OR high end hp... point being is that with the cam you will most likely loose some low end in sacrafice for higher peak hp, whereas more boost would give you power across the whole powerband, btw; when do you reach full boost? never been in a jrsc car......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourceFed »</TD></TR><TR><TD CLASS="quote">when do you reach full boost? never been in a jrsc car......
Superchargers make 'full' boost the instant you floor the throttle....! That's the point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest »</TD></TR><TR><TD CLASS="quote">I'd go with the cam, since once you realize the JR supercharger is boring and go turbo, it will still be useful
get bent!
why did you even reply? I don't want this to turn into a sc vs turbo or d vs b debate! some idiot always replies with some **** that jacks my threads. Tommorrow I'll check this thread and it will be 6 pages of why a turbo b is way better then my sc d series!
</TD></TR></TABLE>get bent!
You may want to look into a different cam. Maybe one more boost specific. The zex cam is good for n/a. I think you could get a good boost grind from exospeed or even Endyn. With the money you'd save on an exospeed cam you can get the pulley also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underrated »</TD></TR><TR><TD CLASS="quote">You may want to look into a different cam. Maybe one more boost specific. The zex cam is good for n/a. I think you could get a good boost grind from exospeed or even Endyn. With the money you'd save on an exospeed cam you can get the pulley also.</TD></TR></TABLE>
thanks
I was wondering about that. Zex told me it worked great with n/a and f/i and I was kinda
! thanks for the info
more please
thanks
more please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 »</TD></TR><TR><TD CLASS="quote">
thanks
more please</TD></TR></TABLE>
thanks
more please</TD></TR></TABLE>???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">I would do the cam, then later up the boost.
The cam might be able to help you on the top end were your SC starts to fall off.</TD></TR></TABLE>
In order to up the boost should I be getting a boost timing ignition?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 »</TD></TR><TR><TD CLASS="quote">Your money is better spent on a pulley and Hondata. </TD></TR></TABLE>
This is what I was looking at now in addition to the pulley.
This is a kit they have come up with just for the JRSC. It's preprogrammed and at 10psi puts 200hp and 160lb/ft of tq.
http://hondata.com/jrsc_big_boost.html
Here is the only bad side $1300 for Hondata.
http://www.mossperformance.com...35973
But even at $1300 I think it is a pretty decent kit. It includes s200 Hondata, Injectors and all the software is preprogrammed
It sounds like a pretty good deal
What do you think?
What do you think?
Yea that sounds like a good deal.
You can also add the nitrous option which would be really cool on a SC.
The reason it is more expensive is the Hondata ECU will be socketed for OBD2.
Also check out http://www.Wiredspeed.com good deals on Hondata and Injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 »</TD></TR><TR><TD CLASS="quote"> You can also add the nitrous option which would be really cool on a SC. </TD></TR></TABLE>
yea, and the car is allready on the bottle
so that wouldn't be anything new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 »</TD></TR><TR><TD CLASS="quote"> The reason it is more expensive is the Hondata ECU will be socketed for OBD2.</TD></TR></TABLE>
really? my car is allready converted to obd1. That won't be a problem, will it?
would I need the one for the 92-95 civic for $1130.00? if so, cool!
You then just buy Hondata for OBD1 and injectors w/obd2 clips. I would have custom tune made for it. You could contact Payn Technologies there are located in Michigan. This would most likely be a better route to take. Since it would be tuned to you car. It might also be cheaper. The results will be lower since he uses a Mustang Dyno which is usually 15% lower then Dynojet. But it is said to provide a better tune.
crazy_eddy
Jan 19, 2018 08:52 AM
jetpilot
Apr 22, 2004 04:53 PM
wizzards581
Jan 14, 2003 09:37 PM
