Will a D series A/C mount work on a B series in a gsr???
I was wondering if the motor mount that's behind the A/C motor on a D15 work on a B18B going into a GSR. car was theft recovery and is gonna be used as a commuter.. thanks
-danny
-danny
If you want to retain A/C, you will need a Del Sol VTEC bracket and then reuse the D series compressor. If you are using it for just a dampening mount, then any 94+ B series bracket will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">If you want to retain A/C, you will need a Del Sol VTEC bracket and then reuse the D series compressor. If you are using it for just a dampening mount, then any 94+ B series bracket will work.</TD></TR></TABLE>
i have a ek with a gsr with a gsr compressor...which bracket do i use? the del sol vtec or gsr bracket? im thinking gsr since its a gsr motor and a gsr compressor...
and i would use a gsr belt right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddong2lee »</TD></TR><TR><TD CLASS="quote">i have a ek with a gsr with a gsr compressor...which bracket do i use? the del sol vtec or gsr bracket? im thinking gsr since its a gsr motor and a gsr compressor...
and i would use a gsr belt right?</TD></TR></TABLE> JACKED!!!
Integra Type-GSR
Northern California (Sales)
Dec 25, 2012 11:41 AM
LilLowEK
12
Sep 17, 2012 08:51 AM
JDMCRX
Jun 18, 2009 05:11 PM
