what do i need to do to my 0bd1 Ls motor to be able to boost more....
Old Nov 20, 2003 | 09:11 PM
sPaRk'iT's Avatar
Default what do i need to do to my 0bd1 Ls motor to be able to boost more....
What exactly do i need to do to my motor (95Ls) to be able to handle up to at least 10psi??? Please every detail would be great good or bad. thanks
-Bruce
Old Nov 20, 2003 | 10:30 PM
Rod.'s Avatar
Default Re: what do i need to do to my 0bd1 Ls motor to be able to boost more.... (sPaRk'iT)
Tune
Old Nov 20, 2003 | 10:35 PM
B_1_8_hatch's Avatar
turn up the boost with a boost controller . if your getting the right amount of fuel, you'll be able to run 10psi on a stock bottom end with no problems. make sure to upgrade your injectors though. i've ran 10psi on my ls motor with no problems on stock bottom end.
thaiphob's Avatar
Nikon!!!
Default Re: what do i need to do to my 0bd1 Ls motor to be able to boost more.... (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">Tune </TD></TR></TABLE>
nice answer.
need some more info on your current setup. you could build your motor i.e. sleeves, fordged internals. mostly depends on your budget.
Old Nov 20, 2003 | 11:47 PM
sPaRk'iT's Avatar
Default Re: what do i need to do to my 0bd1 Ls motor to be able to boost more.... (thaiphob)
i know tuning has alot to do with it, but all im saying is would it be safe to run around 10psi on a bone stock LS motor?? with bigger injectors/bigger exhaust system, FPR, and good tuning of course, but i think i have found my answer, any more advise would be great tho. thanks!
Old Nov 21, 2003 | 12:11 AM
project dc2's Avatar
how about 14 psi ?? bone stock LS .. got my b20 graph in there too
Old Nov 21, 2003 | 10:03 AM
sPaRk'iT's Avatar
Default Re: what do i need to do to my 0bd1 Ls motor to be able to boost more.... (project dc2)
thats nice, what is ur setup?
Old Nov 21, 2003 | 10:21 AM
88civicHB703's Avatar
bitching hp on stock LS..
Old Nov 21, 2003 | 11:39 AM
quikB18B's Avatar
Default Re: (88civicHB703)
Hondata/440-550cc injectors tuning
Im going to tune to 300 whp or 1 bar whichever comes first in janurary Ill let you guys know how it goes.
10 psi walk in the park with the right tuning
Old Nov 21, 2003 | 11:48 AM
sPaRk'iT's Avatar
Default Re: (quikB18B)
so it seems like, its all in the tuning, thats cool, i just want about 8-10psi only, ill probably take my car to DSR in SJ to tune it and hopefully it'll turn out good. BTW, anybody selling their hondata boost ECU, s200.....????
Old Nov 21, 2003 | 11:51 AM
quikB18B's Avatar
Default Re: (sPaRk'iT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk'iT &raquo;</TD></TR><TR><TD CLASS="quote">so it seems like, its all in the tuning, thats cool, i just want about 8-10psi only, ill probably take my car to DSR in SJ to tune it and hopefully it'll turn out good. BTW, anybody selling their hondata boost ECU, s200.....????</TD></TR></TABLE>
Another plus with hondata is that your already obd1 so you dont have to spend $ on an ecu, or harness
Old Nov 21, 2003 | 01:01 PM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Hondata/440-550cc injectors tuning
10 psi walk in the park with the right tuning </TD></TR></TABLE>
Spoken like a true professional...
Old Nov 21, 2003 | 07:27 PM
since i have obd-0 would it be worth it to get one of those obd-0 to obd-1 harness adapter and upgrade to obd-1 in order to run boost and all?
Old Nov 21, 2003 | 07:31 PM
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civicHB703 &raquo;</TD></TR><TR><TD CLASS="quote">since i have obd-0 would it be worth it to get one of those obd-0 to obd-1 harness adapter and upgrade to obd-1 in order to run boost and all?</TD></TR></TABLE>
thats what I'm doing on my g2....converison harness, OBD1 dizzy, and P75 than gonna run Ubedata or you could stay OBD0 and go Zdyne...but the $900 is keeping me away from that route.
Old Nov 21, 2003 | 09:02 PM
awesome.. lemme know so i could go check it out, since u in MD and all.
Old Nov 22, 2003 | 04:55 AM
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88civicHB703 &raquo;</TD></TR><TR><TD CLASS="quote">awesome.. lemme know so i could go check it out, since u in MD and all.</TD></TR></TABLE>
np...I'll keep you in mind when its all done and ready
DAteg402
Dec 4, 2008 03:09 AM
teggyjeff
Oct 30, 2008 03:26 AM
rayray712
Aug 13, 2008 04:40 PM
94EGcoupe
Aug 5, 2004 09:35 AM
sonicSVT
Jan 29, 2003 08:37 AM
